3D Printing
3D Printing
3D Printing Forum Ender 3 Pro continual issues after initial successful prints - Updated
  • Replies 73 replies
  • Subscribers 336 subscribers
  • Views 16884 views
  • Ender 3D Pro
opalko
opalko over 3 years ago
Hi folks, I have an Ender 3 Pro that I bought about a month ago. Stock machine. I have successfully printed using PLA and PETG filament initially.  I am using stock settings for PLA and PETG in Cura on a Linux machine for slicing.
The last thing I printed was a case, in PLA, for a transistor tester, one of those cheapee ones that work well. The outside of the case printed fine but the screw holders on the inside were a loose nest of filament that had no cohesion. They would just snap off with the touch of the finger. It would never hold screws.  So I tried printing the lower half again. This time the bottom layer did not even go down well. Tried again. This time even worse!
Ok after consulting different forums, I was first told my extrusion temp was too low - stock Cura setting is 200. I bumped it 210. Nope. Then I was told to clean the extruder nozzle, which I did. Nope. Then I was told to check the z step. So I went through the process of calculating that and adjusted it. No difference.
At this point I started over. I
- leveled bed again (still didn't work)
- cleaned nozzle again (still didn't work)
- tried different extraction settings (on/off, speed etc) (still didn't work)
Today I went back to the default settings and tried printing it one more time (and then a second and third attempt..). Now the skirt won't even lay down properly. Any guidance for what is going on or where to start (again) with this? I keep the PLA and PETG in the foil pouches they came in with dessicant but I don't have a dryer or use the oven before printing.
Here is a link to the photo album of first good prints and then the degradation over time to the last picture which is from today of the bottom of the tester case I am trying to print again.
https://photos.app.goo.gl/PmBKJQojMPebxnpJ8
Robert Opalko
    jw0752 over 3 years ago +4
    Hi Robert, I look forward to learning what is causing this.
  • milosrasic98
    milosrasic98 over 3 years ago +4
    Hi! I had a similar issue where the printer just started under extruding, I've tried cleaning the nozzle, bumping up the temperature, switching the nozzle, but nothing helped. As I was trying to fix it…
  • ntewinkel
    ntewinkel over 3 years ago +3
    I had the same issues. For me it was the extruder arm that got a crack in it that you can only see after you take it off. Buying a metal extruder fixed all the issues. i think I’m using the correct name…
  • ntewinkel
    ntewinkel over 3 years ago in reply to ntewinkel
    opalko
    The YouTube algorithm just sent me this video, on dealing with hotend clogs and jams.
    https://youtu.be/fzWj6adWc-Y
    At 5:10 he talks about jams between nozzle and tube. He later shows how to take the hotend apart and push clogs out. This might be worth trying on your printer. https://youtu.be/fzWj6adWc-Y?t=340
  • ntewinkel
    This guy goes into a LOT of detail about how to fix hotend failures: https://youtu.be/uKN0VOuul0o
  • paj
    paj over 3 years ago in reply to opalko
    Hi Robert sorry if you have already tried this but given that the cat gcode prints okay could you  open it in a text editor and compare it with the file for the failed prints and get an idea of the differences in temperature settings etc. I suppose it would take some time to work through the settings but it might be worth it. I posted this already but in a place I think you won’t necessarily see it so apologies if you already read it.
  • ralphjy
    ralphjy over 3 years ago
    Just a quick question?  Have you tried printing other things directly from gcode? I.e. bypass the slicer.  I don’t have an Ender 3, but I’ve seen that there are gcode test prints for it like temperature towers.
    Is it possible that there’s something wrong with your slicer besides the profile?  Have you tried updating the slicer program?  I’m making an assumption that the cat is being printed from gcode directly…
  • ntewinkel
    ntewinkel over 3 years ago in reply to ralphjy
    Good point. opalko do you want my 3D Benchy gcode?  I just sliced it (just a minute ago) for Multicomp black PLA (215 nozzle, 60 build plate) for my Ender-3 Pro. That's the Multicomp filament element14/Farnell/Newark sells.
    If you want to try it, I'll print it here too, to make sure it comes out ok for me.
    It says it will take just under 2 hours to print.
    3DBenchy_PLA.gcode.zip
  • ntewinkel
    ntewinkel over 3 years ago in reply to opalko
    opalko said:
    how would the cat print perfectly after the first print failed?
    Maybe your extrusion speed is set too high?  I recall the cat being very detailed, slow and fine printing, which would not have a very fast extrusion speed. (I don't really know where to look for that setting, sorry)
  • ntewinkel
    I’ve always wanted a benchy Laughing
    so far, so good…
  • ntewinkel
    This is the filament I’m using, in case you want to compare detailed specs…
  • ntewinkel
    Finished and looks petty good actually.
    This is my first ever 3D Benchy, so I’m pretty happy to see it printed well for my settings for element14’s Multicomp brand.
    You can find all the details on their website: https://www.3dbenchy.com
  • opalko
    opalko over 3 years ago in reply to ntewinkel
    Cool. Thank you for the .gcode file. I am going to try it this morning. Fingers crossed!
