3D Printing
3D Printing
3D Printing Forum Ender 3 extruder randomly running backwards at the beginning of print
  • Replies 12 replies
  • Subscribers 337 subscribers
  • Views 6868 views
  • filament spool
  • ender3
nowhere2194
nowhere2194 over 3 years ago
I have an ender 3 that sometimes will just randomly pull all the filament out at the beginning of the print. I have been just stopping the print, resetting the filament, and restarted the print and it works fine. what could be going wrong? any ideas
  • Fred27
    Fred27 over 3 years ago +2
    What do you mean by "randomly pull all the filament out"? It's normal for some to ooze out as the nozzle heats up. The printer will then "wipe its nose" at the side of the build platform before starting…
    dougw over 3 years ago +2
    Some printers have a "change filament" command that ejects the filament. It sounds like this command is somehow being executed. Is there a menu option for this command?
  • robogary
    robogary over 3 years ago +1
    Not sure root cause, but I'd recommend doing basic maintenance to see if that fixes the problem - teardown the extruder, meticulously clean out all the filament pathways including the nozzle (maybe even…
  • gadget.iom
    gadget.iom over 3 years ago in reply to nowhere2194
    Okay.  Do you have a filament run-out sensor?
  • ralphjy
    ralphjy over 3 years ago
    Are you printing from the SD card or via USB?
