3D Printing
3D Printing
3D Printing Forum Ender 3 pro how to stop lifting prints and clogging.
  • Replies 17 replies
  • Answers 4 answers
  • Subscribers 336 subscribers
  • Views 8358 views
Hfbhfb
Hfbhfb over 3 years ago
I have been gifted an Ender 3 Pro for my art department. I’m completely new to 3D printing so having to learn from scratch, so please bear with me.
I tried one print and had some success but the first layer was a little rough. But every print since then hasn’t stuck to the plate. It will outline initially but then it starts pulling up. I read about levelling the bed so I have done this, then I also tried to upping the temperature of the first layer to see if it helped stick. But no joy. I seem to get an outline which lifts and then when it goes to print it clogs/ lifts and never settles. I’ve tried increasing/ decreasing the gap. But it doesn’t seem to help. Any advice would be really appreciated as I’m just stuck and frustrated! Thank you!
  • opalko
    opalko over 3 years ago +4 suggested
    Try increasing the bed temperature and slowing down the print speed. You may be interested in these articles from Creality: https://www.crealitycloud.com/blog/3d-printing-troubleshooting/filament-does…
  • hlipka
    hlipka over 3 years ago +4 suggested
    From the image it looks as if you nozzle is not close enough to the bed - the lines should be squished a little bit, and they need to touch each other. Try a 80x80mm square, just 0.2mm thick - when printing…
  • cstanton
    cstanton over 3 years ago +3 suggested
    1. Level your print bed 2. Dry out your filament, and put it in a dehydrator. 3. Clean your print bed, use high proof alcohol, a gentle scourer. 4. Heat your bed, at least 60degC, make sure your…
  • ntewinkel
    0 ntewinkel over 3 years ago
    I had issues like that due to a broken extruder arm. Maybe check that yours is ok, or replace with a metal one (they’re about $15cad iirc). I have more detailed info and pics here on e14, maybe try searching for Ender and my name. I’m away from my desk, so I’m a bit limited for now.
    Cheers,
    -Nico
  • opalko
    0 opalko over 3 years ago
    https://www.crealitycloud.com/blog/3d-printing-troubleshooting/filament-does-not-disconnect-and-drags-when-printing
    and
    https://www.crealitycloud.com/blog/3d-printing-troubleshooting/3d-print-not-sticking-to-bed-fix
  • Hfbhfb
    0 Hfbhfb over 3 years ago in reply to opalko
    Thanks I’ll give that a go and see if it helps. I did increase the bed temp to 65 degree (printing PLA) so unsure if I can/should take it higher. Like I said I’m a complete newb at this!
  • Hfbhfb
    0 Hfbhfb over 3 years ago in reply to ntewinkel
    Thanks so much will definitely have a look into this too.
  • hlipka
    0 hlipka over 3 years ago
    From the image it looks as if you nozzle is not close enough to the bed - the lines should be squished a little bit, and they need to touch each other. Try a 80x80mm square, just 0.2mm thick - when printing it you can easily check that there are no gaps between the lines. Ideally after peeling of the print its a solid sheet and the lines do not disconnect from each other. Maybe look at https://all3dp.com/2/ender-3-pro-z-offset/ for methods to adjust the Z offset.
  • opalko
    0 opalko over 3 years ago in reply to Hfbhfb
    I think I've had PLA as high as 70. I would only change one variable at a time though. Try slowing the print speed first.
  • Hfbhfb
    0 Hfbhfb over 3 years ago in reply to hlipka
    Thank you. I thought this too but in the middle it seems to not have enough room to push out so just gathers in the nozzle. I read that it should grip a piece of paper lightly now this right? Sorry for the questions!
  • hlipka
    0 hlipka over 3 years ago in reply to Hfbhfb
    You can use a steel ruler (or another object with a known straight edge) to check whether your plate is actually flat. Just place it on the plate and use a flashlight from the other side to see how big the gap gets. A sheet of paper (80g) is about 0.1mm think, which is OK as first approximation of the nozzle distance. You then use the above method to find out which distance is best, and the square also show you when your plate is not flat. When its really warped (more than 0.1mm I would say) you should get a bed probe so the printer can compensate for it.
  • hlipka
    0 hlipka over 3 years ago in reply to opalko
    First two things are: get the plate clean (hot water and dish soap usually help) and get the first layer correct. Only when you did these two things, and they did not help, you try something else. Because when these two aren't OK, nothing else will help you.
  • Hfbhfb
    Okay brilliant. Thanks for this. Really grateful for the advice.
