3D Printing
3D Printing
3D Printing Forum Which 3D Printing file format should I choose?
  • Replies 14 replies
  • Subscribers 337 subscribers
  • Views 3827 views
  • 3D Printer file format
HKPhysicist
HKPhysicist over 1 year ago
Hello Friends,
I am planning to hire a graphic designer to design an enclosure for my new battery temperature monitor.
Then, I will take the design file to a friend`s laboratory and print the enclosure.
As I am new to 3D printing, here are my questions:
  1. Which file format should I choose so that it can be printed across most 3D printers?
  2. Which material (plastic?) should I choose for my enclosure so that it can be considered robust, good looking and commercial grade?
Please give your opinions.   Upside down
  • milosrasic98
    milosrasic98 over 1 year ago +2
    Hi! If you just want to print out the file without doing any modifications, most slicers should work with STL or 3MF files. As for the material choice, could you give a bit more detail on the environment…
  • anniel747
    anniel747 over 1 year ago in reply to HKPhysicist +2 suggested
    www.3dxtech.com/.../flame-retardant
  • HKPhysicist
    HKPhysicist over 1 year ago in reply to anniel747 +1
    Cool! There are UL-rated Flame Retardant (FR) polymers in market! I just order these when I hire a shop to print my enclosures!
  • milosrasic98
    0 milosrasic98 over 1 year ago
    Hi!
    If you just want to print out the file without doing any modifications, most slicers should work with STL or 3MF files. As for the material choice, could you give a bit more detail on the environment and temperatures expected around the enclosure?
  • HKPhysicist
    0 HKPhysicist over 1 year ago in reply to milosrasic98
    Hello Friend,
    Thanks for your kind response.
    1. I hope my enclosure works around from 0 degree C to about 65C, as most consumer grade products do.
    2. I also hope the enclosure is fire-retardant so that it won't start a fire by itself.
    3. Also, there are different colours for me to choose.  Upside down
  • anniel747
    0 anniel747 over 1 year ago in reply to HKPhysicist
  • HKPhysicist
    0 HKPhysicist over 1 year ago in reply to anniel747
    Cool!
    I just order these when I hire a shop to print my enclosures! Laughing
    0 dougw over 1 year ago
    .STL can be handled by virtually all printing systems.
    For 65C you cannot use PLA. You would need a filament with a much higher melting temperature than PLA.
    ABS is supposed to be good up to 80C, but I have not tested it at that temperature.
  • Umuju
    0 Umuju over 1 year ago
    For strength and temperature resistance, I would think ASA would probably be your best choice of material. It gives great impact and UV resistance so it could be located outside if necessary. If you are looking for something that is flame retardant or will be located inside and can possibly catch fire, I would suggest a flame-retardant Nylon. Materials like ABS and ASA could produce some toxic fumes when burned. I’ll second the statement about STL format for saving as I haven’t encountered a slicer that didn’t let you import this type of file.
  • beacon_dave
    0 beacon_dave over 1 year ago
    BASF Ultrafuse 316L
  • HKPhysicist
    0 HKPhysicist over 1 year ago in reply to Umuju
    Yes, my enclosure is for household indoor application - flame-retardant Nylon.
    I also recall an old news reporting that users died of frequent 3D printing jobs owing to toxic fume produced during their jobs.
  • HKPhysicist
    Another question is:
    • Which free-to-use software (proprietary) or open source software can read and open STL file quickly?
    I did try FreeCAD but it is so slow that sometimes it takes almost 30 minutes to open a file.  When I rotate the model, it takes another many minutes to finish. Disappointed
  • cstanton
    0 cstanton over 1 year ago in reply to HKPhysicist
    OpenSCAD and variants thereof.
    You may need to review your rendering hardware and storage speed.
