3D Printing
3D Printing
3D Printing Forum Cheap CNC Machine
  • Subscribers 343 subscribers
  • Views 882 views
  • cnc_mill
Cheap CNC Machine
djfraz
djfraz over 9 years ago
Apologies if this is in the wrong section.
I've been looking for a cheap CNC Mill, as i am planning on using it for PCB Milling and not looking to spend over £300/$350. I've found a model which seams to be going for between £150-£200/$180-$250 (I've included the link for one below)
DIY 3 Axis Engraver Machine PCB Milling Wood Carving Engraving Router Kit CNC | eBay
Has anyone used one of these before or have any other suggestions for a cheap cnc mill, it doesn't need a big work area. I have been thinking about just buying a load of aluminium extrusions and making one form scratch, just i dont have the time and from looking this would appear to be a very expensive option.
  • clem57
    clem57 over 9 years ago +3
    Ilan Moyer's Online Portfolio gives some idea. You really should create specs first to see if what you get fits your goals. Clem
  • clem57
    Clem
  • djfraz
    djfraz over 9 years ago in reply to clem57
    Perfect, this is exactly the sort of thing I have been looking for. I'll have a proper look through his thesis and see how I can replicate it.
  • jeremy.f.medlin
    jeremy.f.medlin over 9 years ago in reply to djfraz
    Duncan,
    If the reason why you are looking for a cheap pcb mill is simply to mill pcb boards, it may be worth it to look at the process for a cheaper resist method. In my limited experience with cheap cnc mills, they are only adequate when they work, but are very finicky and the back end is much more complex than simply exporting an image to toner and etching preclad copper. Just a thought.
    balearicdynamics over 9 years ago
    The link you posted on ebay reports: The listing has been removed
    image Enrico
