3D Printing
3D Printing
3D Printing Forum Help making 3D scans of faces into masks
  • Subscribers 342 subscribers
  • Views 965 views
charliecharles
charliecharles over 7 years ago
Hi, so I'm working on a new art project where I turn 3D scans of people's faces into 3D printed masks that can be worn. I need to figure out the most streamlined/easy way to do this. I guess I need guidance on what 3D scanning app/ software would be best catered to faces? Ideally I'd need to cut/edit the facial scan to be thin and inverse on the inside so that it fits onto a person's face. I know the process of editing the scans down to the desired mask won't be easy but I guess I need to start with scanning and turning them into stl's before I can worry about that.
In terms of cameras: I have access to a DSLR from the library but I also own a Pixel 3.
In terms of printing: I have access to the public Library's 3D printers that are already loaded with free filament, and have checked to make sure they're big enough to handle a human sized face mask.
Any help would be appreciated.
  • charliecharles
    Hi, so I'm working on a new art project where I turn 3D free netflix scans of people's faces into 3D printed masks that can be worn. tech news I need to figure out the most streamlined/easy way to do this. I guess I need guidance on what 3D scanning app/ software would be best catered to faces? Ideally I'd need to cut/edit the facial scan to be thin and inverse on the inside so that it fits onto a person's face. I know the process of editing the scans down to the desired mask won't be easy but I guess I need to start with scanning and turning them into stl's before I can worry about that.
  • daveoutlaw
    daveoutlaw over 7 years ago in reply to charliecharles
    Hi Charles
    I just purchased a structure sensor scanner that fits on my iPad for $ 400. it features colored scans of faces. it seems to work really well as it imposes a color print on a crude scan of your head, the combination is very close to a lifelike scan. the file can be converted into an stl for a print in color scan, but it cost $8 to get it converted. then if you want a color print it can be sent to any service bureau. it does take some practice to get a good scan but it does it in under 3 min. the nice feature os you can take it anywhere as opposed to scanners that have to stationed next to a computer. it's not perfect but closer to anything I have used previously.
