3D Printing
3D Printing
Documents 3D Printing 101 Course 2: Introduction and Basic Designs
  • Author Author: pchan
  • Date Created: 12 Aug 2014 2:38 PM Date Created
  • Last Updated Last Updated: 8 Oct 2021 7:53 AM
  • Views 3157 views
  • Likes 8 likes
  • Comments 20 comments
Unfortunately this video is no longer available.
ObjectiveProvide overview of Additive Manufacturing and basic concepts needed to create 3D printed designs.
What’s coveredAfter gaining an understanding layered adhesion, filament materials and basic CAD Concepts, you will be guided to create 3D objects and repositories for printing and sharing designs.
Instructor Kirk Hausman, co-author, 3D Printing for Dummies, and professor, Texas A&M University
Ask Kirk a Question
  • designs
  • 2:
  • 101
  • 3d
  • and
  • printing
  • basic
  • course
  • introduction
  • lbittner
    lbittner over 12 years ago +1
    Hello all, This post is to let you know that Kirk has had an accident that has temporarily rendered him unable to speak, so the rest of the videos in the class (3, 4 and 5) are also temporarily delayed…
    e14 Contributor over 12 years ago +1
    Thanks Kirk for the tutorials. Sorry to hear about your accident, I wish you speedy recovery.
    DAB over 12 years ago
    Very good post.
    I had assumed that some sort of release agent was needed, but I had not thought about a contact agent as well.
    I assume that there is some need to clean the bed surface after a print, but can you reuse a prepared surface after you have printed something?
    I also assume that you will go more into the CAD design process in the next video.
    Look forward to the next class.
    Very good post.
    e14 Contributor over 12 years ago in reply to DAB
    For PLA, the glue stick works well and I just give it another pass where it has been pulled away at the end of each print. For ABS, there is usually enough "ABS Juice" so that a quick pass with a cotton ball and acetone alone will spread enough ABS film to cover the gaps. I clean the entire build plate after every 100-odd hours of printing just as a matter of course, but some have kept using the same plate for a really long time.
    Kirk
    I agree with DAB on the continued elaboration of the CAD system. If you could, explain how you were able to print threads on the bolt you used as one of your visual aids. It would be very helpful. Thank you.
    e14 Contributor over 12 years ago in reply to e14 Contributor
    Eric, the simple answer is that I used a different CAD package with screw thread generating capabilities, but I will show you how to adapt other's designs and use parametric screw threads as well!
