555 Timers
555 Timers
Forum 555 timer and beyond
Join 555 Timers to participate - click to join for free!
  • Replies 7 replies
  • Subscribers 51 subscribers
  • Views 2654 views
Limster10
Limster10 over 4 years ago
I've been studying the 555 Timer and I need to learn more then LED lighting: A stable, mono Stable and bi stable mode with IC's
My configuration: push button --> to 555 Timer--> Mini Solenoid and press the solenoid triggers. (what resistor if needed for solenoid)
  • KennyMillar
    KennyMillar over 4 years ago +5 suggested
    Hi Limster10 The 555 Is nice - it's been a mainstay of electronics for decades! I'm glad you are studying it. Using it to drive a solenoid is neat idea too. It's hard to give you any specific answer…
  • beacon_dave
    beacon_dave over 3 years ago +3 verified
    Perhaps join Derek over at 'DC to Daylight' where he shows you how to drive a relay coil, do the math, and demonstrates why you may want to use a diode across the coil: /challenges-projects/element14…
  • Limster10
    Limster10 over 4 years ago +1
    Kenny thank you for that. I'm looking into using DIP Transistor or ceramic capacitors. No MOSFET on hand. can cannibalize it from old tech. to too you back, going to study this odea
  • KennyMillar
    0 KennyMillar over 4 years ago
    Hi Limster10
    Using it to drive a solenoid is neat idea too. It's hard to give you any specific answer without seeing a schematic of what you're doing. (Even a hand draw sketch is fine!)
    Solenoids are inuductive devices, and if you wire it directly to a 555, you stand the chance of damaging the timer chip.
    Look at the datasheet for your specific 555 and see what the maximum current source is on the output, and pay specific attention the maximum ratings for the device.
    If it were me, I would connect the 555 to a Transistor, or MOSFET to drive the solenoid, with an appropriate diode across the solenoid windings to snub any back-emf.
    • Vote Up +5 Vote Down
  • Limster10
    0 Limster10 over 4 years ago
  • AE7HD
    0 AE7HD over 3 years ago
    Not nearly enough information. What solenoid? Voltage and current? Do you mean you want to use the 555 as a monostable so the solenoid stays on for a minimum time? What if the button is held down longer? Do you want it to keep the solenoid on, then, or always shut off after the monostable time?
    You'll almost certainly need a driver transistor (Bipolar or MOSFET) and you WILL need a flyback diode so the inductive kick does not destroy the semiconductors.
  • beacon_dave
    +1 beacon_dave over 3 years ago
    /challenges-projects/element14-presents/dc-to-daylight/w/documents/27565/dc-to-daylight-09-how-electromechanical-relays-work?ICID=dctodaylight-episode-list
    /challenges-projects/element14-presents/dc-to-daylight/w/documents/27596/dc-to-daylight-10-using-relays-to-make-a-vegas-style-sign?ICID=dctodaylight-episode-list
    As a bonus, a 555 timer makes a guest appearance in the second one.
  • Limster10
    0 Limster10 over 3 years ago
    Hello KennyM, Beacon_dave,AZ7HD and all. thank you much still working on this project. Your insight is very useful and leading.
    I am picking up additional clarity when I open small devises I find around.  I open a pair of hair clipper (small size: trimming) and inside was the exact PCB I want to design without my solenoid.
    So I'm at the design of implementing wiring for the solenoid, 555 timer to on? Off button.
    Please keep your suggestions coming. will keep U updated.
    Limster10
  • AE7HD
    0 AE7HD over 3 years ago in reply to Limster10
    That was confusing and didn't clarify anything.
  • Limster10
    0 Limster10 over 3 years ago in reply to AE7HD
    AE7HD,  I am still researching and forming my design.  I am not schooled in this tech.  I am a newbie and building my skill set as I grow.  I am unable to explain with full clarity of what I am to accomplish.   So thank you.  This is and Idea which I have a patent with.
    Limster10
