555 Timers
555 Timers
Forum Analysis of a 555 circuit design, will it work, maybe there is a better way
Join 555 Timers to participate - click to join for free!
  • Replies 24 replies
  • Subscribers 48 subscribers
  • Views 3992 views
  • 555 timer
  • circuit design
colporteur
colporteur over 2 years ago
I'm looking to build an End of Train (EOT) circuit. The model railroad folks I hang out with, just purchased a commercial unit. After gagging at the price, I figured why not build one.
My search found this resource https://techlib.com/area_50/Readers/Lennie/End%20of%20Train-1.pdf complete with PCB. Unfortunately all the links are dead so I had to generate a schematic from the PCB layout.
Question: Will the circuit work? Are there any reasons for the design?
Instead of bread boarding the design I figured the folks that hang out here are great and offering solutions. Tapping into the experience of the members surely helps. Nothing like experience to find a solution fast.
I have some concerns with the circuit. I couldn't found a 555 circuit that uses pin 7 as an output. I took a look through Cabe Force Essential 555 IC book (Cabe hangs out here:) and found nothing like this beast.
I'm not sure of the design. It looks like nothing I have found.
I'm thinking it would have been easier to just start from scratch.
  • scottiebabe
    scottiebabe over 2 years ago +3
    Perhaps pin 1 is here?
  • beacon_dave
    beacon_dave over 2 years ago +3
    colporteur said: Unfortunately all the links are dead so I had to generate a schematic from the PCB layout. Flashing Rear-End Device For DCC Systems https://web.archive.org/web/20140926093814/http…
    dougw over 2 years ago +2
    What flashing rate do you need? You can buy LEDs that automatically flash:  PRO SIGNAL PSG91916 If you need other rates you could try: https://evandesigns.com/products/flashing-leds-for-hobbies…
  • beacon_dave
    0 beacon_dave over 2 years ago in reply to Jan Cumps
    Looks like some have air generators to recharge the battery amongst other tech...
    https://assets.new.siemens.com/siemens/assets/api/uuid:12efd9a7-8e67-4023-bb3a-61f0e450f90c/sie-bro-end-of-train-brochure.pdf
    It's gonna be tight to fit all that on a PCB the size of a NE 555 D SMD Slight smile
  • jc2048
    0 jc2048 over 2 years ago in reply to colporteur
    The constant is ln(2).
    The 2 comes from the relationship between the switching thresholds. When charging, the lower threshold is twice as far away from VCC as the upper threshold. When discharging, the upper threshold is twice as far away from 0V as the lower one. The natural log is involved because the charging curve is exponential in shape.
    If you want to delve down further, and work it out from first principles, you'll need to read up about RC time constants, and more generally about circuit analysis.
  • aswinvenu
    0 aswinvenu over 2 years ago in reply to colporteur
    Pin 5 is the Control Voltage (CV). Internally this voltage is generated using a voltage divider. Adding a capacitor will help to produce more a stable control voltage. Good practice is definitely to use the cap.
    The design I shared use the same Resistor R2 for both charging and discharging the Cap C3. If you search for astable multivibrator using NE555 you can find design using two resistor solutions as well.
  • beacon_dave
    Looks like it has been taken from the left half of this bipolar LED driver circuit:
    https://web.archive.org/web/20140910104816/http://home.cogeco.ca/~rpaisley4/LM555.html#15
