Transportation & Automotive
Blog A Smart Car Key - What's Inside?
Join Transportation & Automotive to participate - click to join for free!
  • Date Created: 27 Dec 2020 7:21 PM Date Created
  • Views 15494 views
  • Likes 13 likes
  • Comments 20 comments
  • automotive
  • mercedes-benz
27 Dec 2020
I opened an end-of-life smart car key.
It uses radio for locking / unlocking and IR to switch the vehicle off and on.
A deep dive is available here.
The type of key here is one that you can use from a distance to open or close the car, but that you have to physically plug into a dashboard slot to start the engine.
When the key is removed, the engine stops.
The locking /  unlocking mechanism works from a distance. A few 10s of meters. It's a radio circuit powered by a coin cell.
(true story: if you press the key against your temple when using it, the range is extended by several 10s of meters)
To activate the car and be able to run the engine, you have to insert the key into a dedicated receptacle in the dashboard.
A bidirectional infrared bridge communicates between dashboard and key. That circuit is powered via induction.
The coil on the key gets power from a coil in the receptacle.
Let's see how many components can be identified. Chime in if you have more info.
1: unknown function
Maxwell 1436 PQT 711011 Q2 W
The only reference I could find was other similar keys.
2: unknown
ROBINIE 441KP14
I saw the following different codenames on the internet: FICHTE, APFEL, WEIDE
All are German names for trees:
Acacia, Fig, Appel, Willow
Probably an ASIC or mistified OEM.
3: memory
5ACAT 439YTHS
This is a Microchip 25AA640A SPI EEPROM:
4: Schottky diode
45 SOT-23 package is a jellybean Schottky
5: tantalium capacitor
476 6K 430
47 µF, problably 6.3 V, 1411 package
6: oscillator
manufacturer: Nihon Dempa Kogyo Co., Ltd. (NDK)
18.000  :49
Crystal or resonator, 18 MHz?
7: NPN transistor
H1 SOT-23 package is a jellybean NPN.
A: red LED
B: inductor: extracts power from the car. Powers the IR circuit when starting and while driving. Takes care that the IR circuit doesn't need coin cell power. 190 µH.
C: I saw this before and forgot what it was. I bet it's a fuse. edit: no a TVS. edit no it's a 6.7 nF capacitor.
D: IR sender and receiver. There's a matching inverse pair in the dashboard of the car.
Using my tablet as a detector (digital cameras see iR), I found that the left 2 pins are cathode and anode of the LED.
The two buttons are to open and close the door locks.
  • 14rhb
    14rhb over 5 years ago +5
    Hi Jan, Very interesting and good luck. I love a challenge and spent my 'morning hour catchup' doing some delving and found virtually nothing. A website for a Chinese clone was interesting though as the…
    Jan Cumps over 5 years ago in reply to genebren +5
    Some pictures with the components removed (click to enlarge)
  • jc2048
    jc2048 over 5 years ago in reply to Jan Cumps +5
    Looks to me like the Maxwell chip is doing the radio function [the name 'Maxwell' might be a bit of a clue, I suppose]. Now you've shown us the bottom view of the board, we can see the loop of the aerial…
    genebren over 5 years ago
    Very interesting.  I hope that you are able to identify more of the parts and hopefully post more updates.
    • Vote Up +5 Vote Down
  • jc2048
    Looks to me like the Maxwell chip is doing the radio function [the name 'Maxwell' might be a bit of a clue, I suppose]. Now you've shown us the bottom view of the board, we can see the loop of the aerial: fat track round the bottom and then back up the other side, away from the other components, and no planes under it.
