Business of Engineering
Blog Engineers as Consultants Pt 2: How Do Engineers Find Consulting Gigs?
Join Business of Engineering to participate - click to join for free!
  • Author Author: jamesbenson
  • Date Created: 3 May 2014 7:12 PM Date Created
  • Views 2915 views
  • Comments 6 comments
  • consulting
  • entrepreneurship
  • business
jamesbenson
jamesbenson
3 May 2014
Let's start with a clarifying definition: You're not a self-employed consultant unless you have clients. It's fine to tell people you're a consultant when searching for your first client, but never forget that until someone hires you the correct job title is 'unemployed.' There's nothing wrong in being unemployed for a time, but it is important to at least be honest with yourself for motivation.image
For the readers that have decided to start consulting without at least one client, I'll quickly list some simple ideas for finding clients since you probably don't have the time or interest to read about what you SHOULD have done. Your family will likely remind you of that plenty :).
  • Your Past Employer. If you were at least decent at your previous positions and left on good terms, you likely have some credibility with them. That credibility makes you a low risk proposition for the company to engage, and you may still be familiar with their systems.
  • Existing business contacts. Everyone you know professionally should be aware that you're a consultant. Capable people with a job and no time are wonderful resources for referring work. Take an hour every day to catch up with old contacts, and have some fun with it since nobody wants to talk to a needy charity case. Don't be afraid to ask for any references or ideas, and be sure to see if there is some way you can help them.
  • Online job boards. Indeed.com is good for full time contract-to-hire or project-based jobs which is really half way to full time employment. Craigslist is a fine resource, but many people posting are not very serious and will low ball you. However you may be in a position to accept poorly-paying work; in which case just make sure you're not being obvious about your position. It's also not a bad idea to review for full-time jobs that you are a perfect fit for, and contact the company suggesting a consulting arrangement.
Now that the easy sources are listed, there is a more elegant, planned approach which takes more unpaid effort but results in long-term payoff. These are things that can be done in the nights and evenings, allowing people to collect a paycheck at their day job while planning and starting the sales process. This is mostly about understanding yourself in order to identify and acquire the best clients for you.
First, consultants needs to know exactly what they want to do, and what they don't want to do. Identify your existing expertise and expertise you'd like to gain. Why would someone want to hire you? How can you make them money? What are all the ways you can confidently explain this to a potential client? How would you explain it to a layman? How would you want people to describe your job?
Next, what type of company or person would want to hire you to do that job? There is no chance that clients will start knocking on your door just because you are putting out good consulting-related vibrations. You need to know your customer before you chase them down. Identify the companies, and then use the company website, LinkedIn, and Google to determine who the best people are to connect with. In particularly well-matched cases, I have connected with potential clients by making sure I meet them at conferences or other events. (Just don't mention that the meeting was a planned occurrence and it won't be awkward.)
Finally, with a confident understanding of why you are worth hiring, and a list of people/companies that are likely to agree with your assessment, start connecting with them. The list above is the best place to start but won't cast a wide enough net. I believe that visiting and/or cold calling is a lost art; many people welcome a carefully worded and well timed solicitation such as, 'We have the same background and interests, so I'd like to learn more about your business.' Developing the skills to properly word and time such an introduction takes experience, so don't be discouraged if you piss the first few people off sounding like a pushy salesman. Not every lead will turn into a client, so expect to burn a few while learning and save the best for last.
Remember: you're not a consultant until you sign a client. Completing most sales and marketing work before leaving your current job is the best possible play. Plus, if you have your sales pitch put together, it will be easy to turn your current employer into your first client. A part-time engagement is often beneficial for both company and employee as the transition occurs.
James Benson is writing a series on 'Engineers As Consultants' to educate and encourage salaried engineers to consider if hanging a shingle is right for them. New posts on the first Monday of every month.
Pt. 1: So You Want To Be A Consultant
Pt. 2: How Do Engineers Find Consulting Gigs?
Pt. 3: How To Price Consulting Services?
Pt. 4: How To Keep A Client?
Pt. 5: Finding The Best Client Mix
Pt. 6: How To Turn Down A Client
Pt. 7: How to Write a Client Acceptance Clause
Pt 8: Business Structures
Pt. 9: Taxes, Writeoffs, and Accounting
Pt. 10: When Subcontractors Quit
Pt. 11: When a Client Turns into a Deadbeat
Pt. 12: Getting Paid with Company Stock
Pt. 13: How to Assign IP Ownership in a Contract
Pt. 14: Annual Review
Pt. 15: How to Take Vacation
Pt. 16: How to Engage Peers
    DAB over 12 years ago +1
    Hi James, Good post. I think most consultants initially get boost from word of mouth recommendations by friends at companies that "need" you skills for short periods of time. You also need to do a bit…
  • jamesbenson
    jamesbenson over 12 years ago in reply to DAB +1
    Good call on the PR methods, DAB. There are many ways to get jobs, however having an uninterested 3rd party vouch for one's work is one of the most credible endorsements to get.
  • fuffkin
    fuffkin over 12 years ago
    Hi James,
    I think the easiest way to entree into this is the half-way house of being a contractor for a while (often through an agency). It allows you to test whether you've got what it takes and get you used to starting your own company and all that entails. If you can survive in this environment - in my experience you get about a week to prove you can do the job or you're fired - you gain confidence, track record, clients and cash flow.
    Most companies are pretty flexible with hours these days and it gives you the opportunity to add in true consulting gigs in parallel. As you grow the consulting you can cut down the contracting and vice versa during quiet periods. You can also build up "zero hour" contracts as you scale down / leave contracts for support and maintenance as and when. These can also help the overall cash flow and client base.
    Jon
  • fuffkin
    Hi James,
    Jon
  • jamesbenson
    jamesbenson over 12 years ago in reply to fuffkin
    Thanks for the comment Jon.  The idea to go work for a consulting firm before striking out along sounds like a great plan.  I don't have any experience with taking on gigs this way, but the idea of having someone else deal with the sales and overhead would be an excellent way to  get started.  However I wonder if the consulting firms write contracts in a way that restricts the moves a previous staff member can make after they walk out. At the very least I'm sure they don't let their people leave while poaching clients!
  • fuffkin
    fuffkin over 12 years ago in reply to jamesbenson
    Hi James,
    I was thinking more in terms of job agencies rather than consulting firms. Basically, they place you in a contract, generally for an hourly rate and a maximum number of hours per week. You invoice the agency and they invoice the client putting on their markup. The great thing about this, is that the agency "buffers" the transaction with the client and will typically will pay you weekly (even though they may be on 3 month terms with the client).
    As you are not an employee of either the agency (they absolutely don't want this because of the paperwork) or the client you are free to do other work.
    Generally there will be a clause in the contract that prohibits you from going directly back to the customer after the contract end, unless through them. This is typically 6 months.
    I've done / do it both ways. If you are direct with a customer, you can charge a higher rate but you need to balance this with the hassle of chasing payment from the client. I had one that would take regularly take 3 months to pay each invoice. If you are just starting out this can be a killer. It's often less stressful (certainly when you are starting out) to go through an agency. You can literally be paid within a couple of weeks of starting and have instant cash flow. In fact I will now only work for agencies that pay weekly (which most do). When you mix the two, it doesn't matter so much that the direct clients take longer to pay as you are earning a base cash flow from the agency work.
    Jon
  • jamesbenson
    That seems like a great arrangement.  Glad you brought it up.  My next article in the series is about finding the right client balance - I'm sure you'll have your experiences to comment on how agencies have helped you in the past maintain a decent cash flow!
