Business of Engineering
Blog Lenovo And Qualcomm Introduce A Laptop That Has An ARM But No Leg
Join Business of Engineering to participate - click to join for free!
  • Author Author: ipv1
  • Date Created: 30 May 2019 3:48 AM Date Created
  • Views 968 views
  • inovation
  • computex
  • laptop
  • arm
  • news
ipv1
ipv1
30 May 2019
When the Raspberry Pi was introduced in the classroom as a viable desktop replacement, many were skeptical to the processing power and software ecosystem that came with the single board computer. Then came the Pitop and things have never been the same. Enter Computex 2019 on 26th May in Taipei, where the future of technology is showcased and one of the unexpected demos was Qualcomm Snapdragon 8cx and it's partnership with Lenovo. Codenamed Project Limitless, a 2-in-1 laptop was on display that is powered by Snapdragon SOC and runs Windows 10 no less. It looks like the Yoga convertible that has induced mixed feelings in the users.
So this was bound to happen right? The kicker is the benchmarks using PCmark10, according to which the 8cx actually beats an 8th Generation i5 while running MS Office applications. The Snapdragon was running these apps in emulation so the numbers are even more impressive. When it comes to battery life, well it is just not fair competition and we hope that we can get our hands on one soon. The demo unit had the X55 5G modem as part of the always connected theme and we cannot help but wonder what this means for the future of portable computers this holiday season.
As far as the app development is concerned, the cross platform framework Electron will be supporting ARM on Windows later this year. Electron is the same technology that powers Visual Studio Code as well as desktop clients for the like of Slack and Discord. On the gaming end, Unity is being recompiled for ARM and the results are promising.
So the question is, will you be looking at ARM portables to replace your laptop or will you wait till more manufacturers come up with similar offerings.
  • jomoenginer
    jomoenginer over 7 years ago +2
    Aren't many Chromebooks using an ARM processor? The Snapdragon 8c is interesting and the Adreno 680 GPU is impressive supporting OpenGL-ES 3.2 and Direct3D 12 for Windows. It has been interesting to see…
  • clem57
    clem57 over 7 years ago +1
    I am impressed to say the least. Here are the specs: Latest DirectX 12 API Advanced Camera and Video capabilities: Cinema core with VP9 & H.265 decoder and 2nd Gen HDR Playback; High efficiency video encoder…
  • clem57
    • Latest DirectX 12 API
    • Advanced Camera and Video capabilities: Cinema core with VP9 & H.265 decoder and 2nd Gen HDR Playback; High efficiency video encoder
    • Dual 4K external displays
    • Connected Standby / Instant On
    • Multi-gigabit speeds for virtually seamless cloud connectivity/computing: up to 2Gbps LTE
    • Location Aware for app accuracy
    • Wi-Fi: MU-MIMO, Multi-gigabit Wi-Fi, Dual-band simultaneous (DBS), Integrated baseband
    • 4th Generation Qualcomm AI Engine
    • Enhanced voice assistant experiences for Alexa and Cortana with Qualcomm Aqstic technology
    • Supports all versions Windows 10 (Enterprise, Pro, Home)
    • Improved crypto-security
    • Remote management and location awareness for enterprise efficiency
    • Advanced location features:
      • Low Power Geofencing and Tracking
      • Sensor-assisted Navigation
      • Pedestrian Navigation
    • Sensors: Qualcomm All-Ways AwareTm technology
    • Charging: QualcommRegistered Quick ChargeTm 4+ technology
    Specifications
    5G
    5G Chipset: QualcommRegistered SnapdragonTm X55 Modem
    5G Technology: 5G NR
    5G Spectrum: mmWave, sub-6 GHz, 5G/4G spectrum sharing
    5G Modes: FDD, TDD, SA (standalone), NSA (non-standalone)
    5G mmWave specs: 800 MHz bandwidth, 8 carriers, 2x2 MIMO
    5G sub-6 GHz specs: 200 MHz bandwidth, 4x4 MIMO
    5G Peak Download Speed: 7 Gbps
    5G Peak Upload Speed: 3 Gbps
    5G RF: 100 MHz envelope tracking, Adaptive antenna tuning
    CPU
    CPU Cores: QualcommRegistered KryoTm 495 CPU, Octa-core CPU
    CPU Architecture: 64-bit
    Process
    Process Technology: 7 nm
    DSP
    DSP Technology: QualcommRegistered HexagonTm 690 Processor, Qualcomm All-Ways AwareTm technology
    Cellular Modem
    Modem Name: QualcommRegistered SnapdragonTm X24 LTE modem
    LTE Category
    Downlink LTE Category: LTE Category 20
    LTE Downlink Features
    Downlink LTE Streams: Maximum 20 spatial streams
    Downlink Carrier Aggregation: 7x20 MHz carrier aggregation
    Downlink LTE MIMO: Up to 4x4 MIMO on five carriers, Full-Dimension MIMO (FD-MIMO)
    Downlink QAM: Up to 256-QAM
    LTE Uplink Features
    Uplink Technology: QualcommRegistered SnapdragonTm Upload+, Uplink Data Compression (UDC)
    Uplink Carrier Aggregation: 3x20 MHz carrier aggregation
    Uplink LTE Streams: Up to 2x 106Mbps LTE streams
    Uplink QAM: Up to 256-QAM
    LTE Speed
    LTE Peak Download Speed: 2 Gbps
    LTE Peak Upload Speed: 316 Mbps
    Cellular Technology
    Cellular Technology: WCDMA (DB-DC-HSDPA, DC-HSUPA), TD-SCDMA, CDMA 1x, EV-DO, GSM/EDGE
    LTE Technology: LTE FDD, LTE TDD including CBRS support, LAA, LTE Broadcast
    Wi-Fi
    Wi-Fi Standards: 802.11ad, 802.11ac Wave 2, 802.11a/b/g, 802.11n
    Wi-Fi Spectral Bands: 2.4 GHz, 5 GHz, 60 GHz
    MIMO Configuration: 2x2 (2-stream)
    Bluetooth
    Bluetooth Version: Bluetooth 5.0
    NFC
    Near Field Communications: Supported
    Location
    Satellite Systems Support: Beidou, Galileo, GLONASS, GPS, QZSS, SBAS
    Location Support: QualcommRegistered Location
    Global Emergency Services Support: Assisted GPS, OTDOA (LTE-based positioning)
    RF
    RFFE: QualcommRegistered RF Front-End (RFFE) solution, High-power transmit (HPUE), QualcommRegistered Adaptive Antenna Tuning
    USB
    USB Version: USB 3.1
    Camera
    Image Signal Processor: Qualcomm SpectraTm 390 image signal processor, Dual 14-bit ISPs
    Dual Camera: Up to 16 MP
    Single Camera: Up to 32 MP
    Video Capture (30 FPS): 4K HDR video capture, 4K Ultra HD video capture
    Slow Motion Video Capture: 720p @ 480 FPS
    Video
    Video Playback: Up 4K HDR @ 120fps
    Codec Support: H.265 (HEVC), H.264 (AVC), VP9
    Video Software: Rec. 2020 color gamut video capture, Up to 10-bits per color video capture
    Display
    Max On-Device Display: 4K Ultra HD
    Max External Display: Two 4K Displays
    General Audio
    Audio Technology: Qualcomm TrueWirelessTm Technology, QualcommRegistered Broadcast Audio technology, Qualcomm AqsticTm audio technology, QualcommRegistered aptXTm audio technology
    QualcommRegistered aptXTm audio playback support: QualcommRegistered aptXTm, QualcommRegistered aptXTm HD
    Audio Playback
    Channel output: Surround Sound
    Speaker protection: Speaker protection
    GPU
    GPU Name: QualcommRegistered AdrenoTm 680 GPU
    API Support: DX12
    Memory
    Memory speed: 2133MHz
    Memory Type: LPDDR4x, 8 channels
    Storage
    SSD: NVME SSD
    UFS: UFS 3.0
    *Requires network connection and compatible network.
    ** Battery life varies significantly with settings, usage, and other factors
    Qualcomm Snapdragon, Qualcomm Adreno, Qualcomm Aqstic, Qualcomm Kryo, Qualcomm AI Engine, Qualcomm All-Ways Aware, Qualcomm Quick Charge, Qualcomm Hexagon, Qualcomm Snapdragon Upload+, Qualcomm Spectra, Qualcomm RF Front End, Qualcomm Adaptive Antenna Tuning, Qualcomm Location, Qualcomm Spectra, Qualcomm TrueWireless, Qualcomm Broadcast Audio and Qualcomm aptX are products of Qualcomm Technologies, Inc. and/or its subsidiaries.
    From: https://www.qualcomm.com/products/snapdragon-8cx-compute-platform
    My summary:
    QualcommRegistered KryoTm 495 CPU, Octa-core CPU.
         A 7nm process tech chip with incredible 7-watt TDP allowing multiple days on 1 battery charge.
         The new Adreno 680(GPU), which doubles the memory interface from 64 bits to 128 bits.
    Read more at https://hothardware.com/news/snapdragon-8cx-acpc-windows-10-on-arm-kryo-495#aEQ4VmiAsRZwt00E.99
    Clem
  • jomoenginer
    The Snapdragon 8c is interesting and the Adreno 680 GPU is impressive supporting OpenGL-ES 3.2 and Direct3D 12 for Windows.  It has been interesting to see the evolution of the ARM processor where even HP took a shot, or Moonshot, at creating an ARM based server. I think it is just a matter of time when these start taking a bigger chunk out of the Intel hold on the CPU market.  I do believe they have an ARM fab somewhere I suppose just to be ready.
    At a lower end, I've had my eye on a Pinebook Pro which sports a Rockchip RK3399 SOC with Mali T860 MP4 GPU at a $199 US price range.
