Business of Engineering
Forum mesure ultra sound frequency
Join Business of Engineering to participate - click to join for free!
  • Subscribers 241 subscribers
  • Views 1313 views
  • ultrasound
  • osiliscope
is there a device that can mesure ultra sound and display the results? there is a transducer that emits ultra sound in short bursts and i want to mesure it with an osiliscope mabye ? it has to be handheld since its inside ships. because of the short bursts its hard to mesure with the equipment i have to day.
not sure if right place to post
  • rsc
    rsc over 10 years ago
    We use an oscilloscope to display measured ultrasound from a Bruel & Kjaer microphone.  The pulses are made using a triggered spark gap.
    Scott
    e14 Contributor over 10 years ago in reply to rsc
    and can we read of the KHz even if its in short bursts, like pause the screen and read of the KHz?
  • rsc
    rsc over 10 years ago in reply to e14 Contributor
    You calculate the KHz by dividing by the time between the peaks of the waveform.  A good digital oscilloscope will calculate it for you by using the on-screen measurement cursors. Some instruments have waveform capture and download capability. The issue with ultrasound (or any sound) measurement is triggering on the correct wave.  There are direct waves from the source to the microphone, and there are reflected waves from walls, floor, ceiling, and other objects. All these waves will have different waveform characteristics.  If you want to measure frequency directly, then use a spectrum analyzer.
    Scott
  • michaelwylie
    michaelwylie over 10 years ago
    You could just use another transducer as the receiver and display it on the scope.
    e14 Contributor over 10 years ago in reply to michaelwylie
    Yeah that was my plan, but it has to be easy to learn, im working as a "technician" in a small company. We only have resources to send out one person at the time, so i have to learn the "sales men" to do a quick scan to se if it works. The problem is to find something easy to use, any recommendations for hand held oscilloscopes?
