Code Exchange
Code Exchange
Blog C++ classes and operators
Join Code Exchange to participate - click to join for free!
  • Date Created: 9 Mar 2025 7:23 PM Date Created
  • Views 1718 views
  • operator
  • c++
9 Mar 2025
This is a "classic C++" post, something that's been part of the language since conception: How to use an operator in your class design.
I developed a callback class. Your "gizmo that needs to callback something" would hold an instance of that class (an object). And you 'd assign some function to that object.
Callback<int> cb;
cb.set([]() -> void {
    start_video();
When the time is ripe (usually an event: an interrupt, a mouse click, UART data arrived, ...) you ask the callback class to execute that function. In this blog, I'm pretending that I'm a button, and someone clicked me. The effect should be that the start_video() callback gets executed.
In my original design, you reacted on that by calling the callback class call() method:
bool button1::clicked() {
    cb.call();
This would execute the start_video().
However, in C++ there is a standard way to indicate that something is a call and that you "execute the object" : the operator (). Similar to the operator +, that indicates that you want to add. I want that my class follows that paradigm.
This is how I want that a call should look like:
    cb();
It again should call start_video(). Like the originall call() method did.
Implementing this isn't hard. In my Callback template class, I just had to replace call() by operator ():
class Callback {
public:
	inline void operator()() {
	    // call the registered callback
in reality, my class is template driven, and will accept callbacks with any type / count of parameters. I've removed that for blogging simplicity.
Opinions on this topic may vary. I think that operator() indicates perfectly that you want the callback class to execute the callback handler. Let me know if you have a different preference.
    Jan Cumps over 1 year ago
    Here is how I used this in Raspberry Pico code, where I use a callback when i need data from UART:
    callbackmanager::Callback<void, std::string&> reader;
    reader.set([](std::string& s) -> void { read(s); });
    // read is a Pico function that gets all available data from the controller's UART buffer.
    // it stores the results in the std::string tht's passed to it as a reference.
    In my business logic, that doesn't know anything about Pico or UART, I invoke a read by calling that callback:
    // In my business logic
    void mybusinessclass::read(std::string& s) {
        reader(s);
    The callback class will call that read() function we set earlier, to get the data from the UART, and put it in std::string s.
    I've used explicit types in the code above,
    but you can also use auto:
    reader.set([](auto& s) { read(s); });
    Both constructs are identical, and enforce the same strong type checks. auto is a useful way to (amongst other things) type less.
