Code Exchange
Code Exchange
Blog embedded C++: manage a resource with a tiny* object
Join Code Exchange to participate - click to join for free!
  • Date Created: 5 Apr 2025 12:58 PM Date Created
  • Views 1394 views
  • Comments 11 comments
  • Modern C++
  • c++
5 Apr 2025
*tiny like in: 0 bits of data, 0 code instructions added, 0 clock ticks
scenario: you have a resource that needs to be initialised before use, and deactivated when done. We usually do that by calling some code before the actions, and some code after we're done.
// ... code before you want to activate stepper driver
activate_stepper_driver(true);
// code where you use the stepper
step(15, left);
step(185, right);
activate_stepper_driver(false);
// ... code after you deactivated the driver
We do the bookkeeping ourselves, and take care that we call both functions.
There's a C++ design pattern (RAII) that can handle this for us. You create an object when you need to activate the resource, and it 'll deactivate when it gets out of scope.
Example class - a real world case where my motor burns 0.6 A when the stepper driver is active (motor "hold" current):
class wakeup_drv8711 { // driver out of sleep as long as object in scope
public:
    inline wakeup_drv8711() { gpio_put(nsleep, 1); }
    inline ~wakeup_drv8711() { gpio_put(nsleep, 0); }
... and its use:
    { // enter scope. w constructor gets called
        wakeup_drv8711 w;
        step(15, left);
        step(185, right);
    } // leave scope, w destructor gets called
The driver is activated at line 4 (3 actually), and deactivated at line 8
Thoughts are welcome.
  • embeddedguy
    embeddedguy over 1 year ago
    Not yet sure about this feature but what about malloc() and free() at latter point of time? Is it not that effective anymore against memory leaks?
    Jan Cumps over 1 year ago in reply to embeddedguy
    there is no dynamic memory allocation involved in this.
    (edit:
    you can see that because there is no new() involved in this code.
    also; because there is no data member, this object actually takes 0 bytes, nothing. It only exists in the C++ "conceptual realm".  you don't find anything back in the runtime.
    The only effect is that the code in the constructor is inserted where the scope is entered, and the code in the destructor is inserted where we leave the scope.
    Exactly same effect as the C code at the start the blog
    (edit:
