Code Exchange
Code Exchange
Blog embedded C++: manage a resource with a tiny* object
Join Code Exchange to participate - click to join for free!
  • Date Created: 5 Apr 2025 12:58 PM Date Created
  • Views 1462 views
  • Comments 11 comments
  • Modern C++
  • c++
5 Apr 2025
*tiny like in: 0 bits of data, 0 code instructions added, 0 clock ticks
scenario: you have a resource that needs to be initialised before use, and deactivated when done. We usually do that by calling some code before the actions, and some code after we're done.
// ... code before you want to activate stepper driver
activate_stepper_driver(true);
// code where you use the stepper
step(15, left);
step(185, right);
activate_stepper_driver(false);
// ... code after you deactivated the driver
We do the bookkeeping ourselves, and take care that we call both functions.
There's a C++ design pattern (RAII) that can handle this for us. You create an object when you need to activate the resource, and it 'll deactivate when it gets out of scope.
Example class - a real world case where my motor burns 0.6 A when the stepper driver is active (motor "hold" current):
class wakeup_drv8711 { // driver out of sleep as long as object in scope
public:
    inline wakeup_drv8711() { gpio_put(nsleep, 1); }
    inline ~wakeup_drv8711() { gpio_put(nsleep, 0); }
... and its use:
    { // enter scope. w constructor gets called
        wakeup_drv8711 w;
        step(15, left);
        step(185, right);
    } // leave scope, w destructor gets called
The driver is activated at line 4 (3 actually), and deactivated at line 8
Thoughts are welcome.
  • balajivan1995
    balajivan1995 over 1 year ago
    Even in my company we are advised to use SBRM (Scope based/bound resource management, as explained in original post example). Lifetime of the variables/object created inside the scope will be cleared once it goes out of scope.
    It does make code look ugly though.
  • balajivan1995
    Jan Cumps over 1 year ago in reply to balajivan1995
    How do you think it makes the code look ugly?
  • balajivan1995
    balajivan1995 over 1 year ago in reply to Jan Cumps
    Ok, imagine a function that has a switch case that uses a const,
    void func()
        const int a = getSomeValue();
        switch( a )
            case 0:
                func01();
            break;
            case 1:
                func02();
            break;
            default:
                errorMsg();
            break;
        someFuction();
        someOtherFunction();
    using SBRM ( one of RAII rules), it needs to be rewritten like this so as to limit the scope of that const.
    void func()
            switch( a )
                case 0:
                    func01();
                break;
                case 1:
                    func02();
                break;
                default:
                    errorMsg();
                break;
        someFuction();
    got it
    I'd challenge the coding standard authority. How many bugs did we have the last thousand years? How many of these bugs were because a variable had function scope instead of micro-scope?
    If they say 1, let them show that one piece of code.
