Code Exchange
Code Exchange
Blog embedded C++: manage a resource with a tiny* object
Join Code Exchange to participate - click to join for free!
  • Date Created: 5 Apr 2025 12:58 PM Date Created
  • Views 1394 views
  • Comments 11 comments
  • Modern C++
  • c++
5 Apr 2025
*tiny like in: 0 bits of data, 0 code instructions added, 0 clock ticks
scenario: you have a resource that needs to be initialised before use, and deactivated when done. We usually do that by calling some code before the actions, and some code after we're done.
// ... code before you want to activate stepper driver
activate_stepper_driver(true);
// code where you use the stepper
step(15, left);
step(185, right);
activate_stepper_driver(false);
// ... code after you deactivated the driver
We do the bookkeeping ourselves, and take care that we call both functions.
There's a C++ design pattern (RAII) that can handle this for us. You create an object when you need to activate the resource, and it 'll deactivate when it gets out of scope.
Example class - a real world case where my motor burns 0.6 A when the stepper driver is active (motor "hold" current):
class wakeup_drv8711 { // driver out of sleep as long as object in scope
public:
    inline wakeup_drv8711() { gpio_put(nsleep, 1); }
    inline ~wakeup_drv8711() { gpio_put(nsleep, 0); }
... and its use:
    { // enter scope. w constructor gets called
        wakeup_drv8711 w;
        step(15, left);
        step(185, right);
    } // leave scope, w destructor gets called
The driver is activated at line 4 (3 actually), and deactivated at line 8
Thoughts are welcome.
    Jan Cumps over 1 year ago
    Pre-empting the question: but how much overhead?
    none.
    The "nop" calls are there to "do something" so that the optimiser doesn't completely remove this example code.
    none.
    this code was used for the comparison:
    C
    inline void activate_stepper_driver() { asm("nop"); }
    inline void deactivate_stepper_driver() { asm("nop"); }
    int main() {
        asm("nop");
        activate_stepper_driver();
    // code that uses the stepper here
        deactivate_stepper_driver();
        asm("nop");
        return 0;
    C++
    public:
        inline wakeup_drv8711() { asm("nop"); }
        inline ~wakeup_drv8711() { asm("nop"); }
    int main() {
        asm("nop");
            wakeup_drv8711 w;
        asm("nop");
        return 0;
