Code Exchange
Code Exchange
Blog How I Became an Electrical Engineer Writing Software
Join Code Exchange to participate - click to join for free!
  • Author Author: oneleggedredcow
  • Date Created: 2 Aug 2012 3:11 PM Date Created
  • Views 995 views
oneleggedredcow
oneleggedredcow
2 Aug 2012
Well, the truth is that I always knew that I wanted to write software.  Like most other people in software, my first exposure was through video games.  For me, I think the real draw was building something that was fun to play with.
So, the story is more about how I ended up in electrical engineering.  When I headed off to college, I wasn’t quite sure what my major was going to be.  Before I got on campus, I was pretty sure that I was going to do either computer science or computer engineering.
I remember talking to my father about which major was better and what the different career options were for both of them, and he had some very interesting advice.  His advice was to be an electrical engineer.  His reasoning was that out of the three majors that we were talking about, EE would have the most math and physics.  His claim was that programming could be learned on the job, given a suitable base, but that the underlying principles of what you were programming would not be so easily learned later.  So, while I was in school, I should focus on learning fundamental laws rather than programming languages and syntax.  Languages change and evolve with time, so anything that I learn in school will be dated by the time that I graduate anyway.
I think this was some of the best advice that I ever received.  After being out in industry, his assessment couldn’t be any more correct.  It is definitely possible to learn math/physics type knowledge on the job, but it is much more likely to learn a new programming language or technology.
If you want to write software, take courses about things that are common to all languages: flow control, functions, data structures, etc.  Don’t fret about knowing every language that is out there.  Pick one and know enough to be dangerous.  Changing languages or picking up new tricks can be done on the job, and will probably be required since every company’s environment is a little bit different.
    DAB over 14 years ago
    I followed a similar path, going first for an AS in Electronics and then going for a dual Computer Engineering degree in college.
    I have found that most people who can understand basic logic have very little difficulting in picking up the basics of programming.
    In my day it was viewed more as a Mathematical pursuit, but it was easy to see that the controller aspects of computing would soon dominate their use in industry.
    You are also right about languages.  If you learn one very well, you can adapt to just about any other language easily.  They are all basically the same, some people just like to see things from one aspect or the other, so languages proliferate.  I have found few problems that could not be solved in any computer language.
    Understanding the underlying electronics, however is very key to success.  You need to understand what happens when you transition from a bit of code to the reaction of the attached software.  You need to go back and forth between the two to fully understand the system.
    So I hope you have a successful career and that you get a chance to work on as many interesting problems as I have.
    It has been a great ride for me.
