Code Exchange
Code Exchange
Blog Need help coding
Join Code Exchange to participate - click to join for free!
  • Author Author: rmiltenberger
  • Date Created: 16 Mar 2018 11:24 PM Date Created
  • Views 3079 views
  • Comments 9 comments
Need help coding
rmiltenberger
rmiltenberger
16 Mar 2018
I have 4 sparkfun lummenati 3x3 bParts,
  I having a problem finding a code,
i have them daisy chained would like to make
a top hat band
any help would be greatly appreciated
thanks bob
  • rmiltenberger
    rmiltenberger over 8 years ago +3
    To Shabez, and Dave,, Wow, ok it took some doing, and slit of research. But I have my matrix, up and running. And it's gorgeous... 3x36 lights running... various colors across each successive board...…
    beacon_dave over 8 years ago in reply to rmiltenberger +2
    Here was my first attempt with APA102C LED's & the FastLED library Data on pin 6 Clock on pin 7 #include <FastLED.h> #define NUM_LEDS 1 #define DATA_PIN 6 #define CLOCK_PIN 7 CRGB leds[NUM_LEDS]; void…
    shabaz over 8 years ago in reply to rmiltenberger +2
    Hi Robert, If you can paste the entire output error, it will help, because it will likely mention which line the error was on. Also, precision is key, because you state the error is 'Leds does not name…
  • stevemaka
    stevemaka over 8 years ago
    Now nobody can make APA102C in china, all APA102C in china you bought is fake LED, because of orginal APA supplier didn't provide IC for china factory any more.....i think you can choose APA107 or SK9822 to replace APA102C.
  • rmiltenberger
      SHABEZ,, thank you for your help, Dave the final clue,, thank you....
    The APA102C leds library was not in my Audrino IDE,
      I have some tweaking to do, but I added FastGPIO, as well...
    Bob m
    You guys are just Awesome
    Hi Robert,
    Also, precision is key, because you state the error is 'Leds does not name a type' but there is no identifier called 'Leds' -
    there is one called 'leds' and the capitalisation makes a big difference. So, I can't tell if there is a mistake in the typing of the error message, or some other mistake.
    This ambiguity would not occur, if you can precisely paste the exact output you see.
  • rmiltenberger
    rmiltenberger over 8 years ago in reply to beacon_dave
    when I compile I get Leds does not name a type
    sorry to bother you ,,
    if you want we can text
    617-275-9212
  • rmiltenberger
    Dave
      thanks it's something
    i can only see 30 lines of code,
    it a start
    I've not done anything with this stuff before
    so I'm learning
