      • Japan
      • Vietnam
Code Exchange
Code Exchange
Forum reptilian programming overloads share your Python insight
Join Code Exchange to participate - click to join for free!
  • Replies 2 replies
  • Subscribers 48 subscribers
  • Views 300 views
  • python
  • python venu
  • programming
colporteur
colporteur 7 months ago
I'm attempting to use a simple (I call it that) python script for an SPI LCD 1.3 inch display. Attempting to pip the install of st7789 results in "error: externally-managed-environment".
I found this adafruit tutorial on the basics but I'm looking for more. https://learn.adafruit.com/python-virtual-environment-usage-on-raspberry-pi/basic-venv-usage
The script I am attempting I've used before. Many setting suns before. Now it hits the environment wall. How are python scripts formatted to operate in the environment? Can I use python environment conditioned scripts the same way as bash scripts (i.e. service calls, rc.local...)
Can you share your resources that I can use to come up to speed?
  • balajivan1995
    balajivan1995 3 months ago
    I think the source you have mentioned also describes how to use the script
    Automatically Running at Boot | Python Virtual Environment Usage on Raspberry Pi | Adafruit Learning System
    pi@raspberrypi:~ $ sudo /home/pi/blinka/bin/python3 /home/pi/neopix_spinner.py
    Instead of using the default python, you need to explicitly mention the python present in the venv you have created.
  • colporteur
    colporteur 3 months ago in reply to balajivan1995
    Thanks for the response.
    I did find a solution and documented my process as part of a challenge post.
     Turn on the TV: The toughest part for last coding
