Code Exchange
Code Exchange
Forum First PiFace Script
Join Code Exchange to participate - click to join for free!
  • Subscribers 50 subscribers
  • Views 759 views
  • source_code
  • Code Exchange
First PiFace Script
ge0rgej
ge0rgej over 13 years ago
Hi
Having problems initiating my first PiFace script. I have played around with the Wobbly Chicken script
but am unable to get the script to initiate in the PiFace emulator. The 2 associated files are below
http://pastebin.com/embed_js.php?i=5eb40u1S
http://pastebin.com/embed_js.php?i=ZWAzfJC5
Using TightVNCServer ... at the command prompt I am typing
python Tank_Autofill.py
but all I am getting is the following error -  xlib: extension "RANDR" missing on display ":1.0".
.... and the emulator does not initiate
If I run the piface_test.py that is provided in the piface/python/tests folder ... the emulator / script works
I'm guessing that something is wrong with my coding - any help would be much appreciated
  • ge0rgej
    ok - I've just realised that raspberry_pi_farm should be replaced with Tank_AutoFill
    but now I am getting the following error message
    /usr/lib/python2.7dist-packages/gtk-2.0/gtk/_init_.py:57: GtkWarning: could not open display
    warnings.warn(str(e),_gtk.Warning)
    Again - help appreciated
    e14 Contributor over 13 years ago in reply to ge0rgej
    You're using out of date libraries. You might find it easier to use the new software available here: https://github.com/piface/pifacedigitalio
    There is also documentation and some example code.
