Code Exchange
Code Exchange
Forum Redundant parathensis in C
Join Code Exchange to participate - click to join for free!
  • Replies 26 replies
  • Answers 4 answers
  • Subscribers 54 subscribers
  • Views 3786 views
  • Code Exchange
  • redundant
  • conditional tricky writing style
  • if else construct
  • paranthesis
dr.akshay_1980@yahoo.com
dr.akshay_1980@yahoo.com over 10 years ago
Out of curiosity and experimenting with ANSI C constructs ,I would like to know any means by which we can ignore the empty braces for the conditional statements in C programming??? Does C allow us to do this.
Refer below the sample C code for discussion
int main()
     if()             /// there should no error while writing this, empty parathensis..
     printf("your if  is without parameters...");
else
    printf("if block ignored....");
return 0;
How to implement the above code in C successfully without any errors(compile time/Run time)????? By any means I want to implement above style.
Thanks in advance....
    shabaz over 10 years ago in reply to clem57 +2
    It looks like another interview/college homework type question (they do ask odd questions sometimes). Much like this one: If-Else construct in C language-hello world As you say, nothing for any real practical…
  • amgalbu
    amgalbu over 10 years ago +1 suggested
    According to c grammar, you need to type a boolean expression. So there is no way to create an if without condition
  • amgalbu
    amgalbu over 10 years ago in reply to D_Hersey +1
    @akshay dharma is asking if it is possibile to uae empty braces after a if keyword. That's noto possibile imho. Btw true and false are c++ keywords, and are not allowed in ANSI c (aka c90)
  • amgalbu
    0 amgalbu over 10 years ago in reply to e14 Contributor
    Noto dure you can replace a C keyword with a define...
    0 e14 Contributor over 10 years ago in reply to amgalbu
    This is what I was suggesting:
    #define TRUE 1
    if(TRUE) {
         whatever
    This is one obvious and historical way of making simple
    C if-statements more readable.
    There are many ways to use #define statements in making C
    quite readable to organizational standards.
    That is why #define is called a macro statement,
    with historical roots in various assembly languages.
    0 e14 Contributor over 10 years ago in reply to D_Hersey
    Ok, Don. I was simply puzzled by shift.  Clearly, I missed the point.
  • D_Hersey
    0 D_Hersey over 10 years ago in reply to e14 Contributor
    It's clang association.  When I was a kid they thought I might have been creative, but it's mostly random.
    https://en.wikipedia.org/wiki/Clanging
    Part 2.
    By a new preprocessor, I meant to either (1) change the existing C preprocessor (cpp, which is open source) or (2) write a new one to front-end `cpp`.  I doubt if amending cpp or creating a new preprocessor is worth it.
    Akshay still has not articulated the circumstance where "if()" is generated or derived from something else.  Clearly, one would not create meaningless code like that by hand.
  • gdstew
    0 gdstew over 10 years ago in reply to amgalbu
    Since they are not keywords in C90 there is no problem with creating them using #define. In C99 however they are keywords reserved as part
    of the standard libraries so this would not work.
