Code Exchange
Code Exchange
Forum Redundant parathensis in C
Join Code Exchange to participate - click to join for free!
  • Replies 26 replies
  • Answers 4 answers
  • Subscribers 54 subscribers
  • Views 3780 views
  • Code Exchange
  • redundant
  • conditional tricky writing style
  • if else construct
  • paranthesis
dr.akshay_1980@yahoo.com
dr.akshay_1980@yahoo.com over 10 years ago
Out of curiosity and experimenting with ANSI C constructs ,I would like to know any means by which we can ignore the empty braces for the conditional statements in C programming??? Does C allow us to do this.
Refer below the sample C code for discussion
int main()
     if()             /// there should no error while writing this, empty parathensis..
     printf("your if  is without parameters...");
else
    printf("if block ignored....");
return 0;
How to implement the above code in C successfully without any errors(compile time/Run time)????? By any means I want to implement above style.
Thanks in advance....
    shabaz over 10 years ago in reply to clem57 +2
    It looks like another interview/college homework type question (they do ask odd questions sometimes). Much like this one: If-Else construct in C language-hello world As you say, nothing for any real practical…
  • amgalbu
    amgalbu over 10 years ago +1 suggested
    According to c grammar, you need to type a boolean expression. So there is no way to create an if without condition
  • amgalbu
    amgalbu over 10 years ago in reply to D_Hersey +1
    @akshay dharma is asking if it is possibile to uae empty braces after a if keyword. That's noto possibile imho. Btw true and false are c++ keywords, and are not allowed in ANSI c (aka c90)
  • dr.akshay_1980@yahoo.com
    0 dr.akshay_1980@yahoo.com over 10 years ago in reply to clem57
    Hi Clem, I do agree with you, but after all C logic can be bypassed as we people have developed the C. In this case my intention is that you people should come out with OUT OF BOX solution for this , being an embedded developer I generally come across situations where I have to convert the C++/JAVA code into C(for lower end systems that don't support OOPS), I was just fiddling with if else construct....
    The approach from my end is to befool the compiler anyhow and lets bypass the conditional check for if using pragma directives or assert macros... i was looking ahead in this direction...
    Can we come out for its solution...???
    Hi all, I do agree with you people and very much conscious about C language principles, but after all C logic can be bypassed as we people have only developed the C. In this case my intention is that you people should come out with OUT OF BOX solution for this , being an embedded developer I generally come across situations where I have to convert the C++/JAVA code into C(for lower end systems that don't support OOPS), I was just fiddling with if else construct....
    The approach from my end is to befool the compiler anyhow and lets bypass the conditional check for if using pragma directives or assert macros... I was looking ahead in this direction...
  • clem57
    0 clem57 over 10 years ago
    Your style fits poorly and is ill conceived. A style needs universal suffrage.
    Clem
  • amgalbu
    0 amgalbu over 10 years ago in reply to dr.akshay_1980@yahoo.com
    Can you point out a practical case?
    Empty braces could be always evaluated ad either true or false (depending on the semantica you want to adopt) so you can simply remove the if()
    0 e14 Contributor over 10 years ago in reply to dr.akshay_1980@yahoo.com
    A nil boolean expression has no cognitive meaning and is therefore correctly diagnosed as missing by `gcc`.  I suggest that you either code if(1) or #define TRUE 1 and use if(TRUE).
    Don't fight something that isn't going to change because there is no point to do so.
  • D_Hersey
    0 D_Hersey over 10 years ago in reply to e14 Contributor
    https://en.wikipedia.org/wiki/Three-valued_logic
  • amgalbu
    0 amgalbu over 10 years ago in reply to D_Hersey
    That's really interesting. Can't think of a practical usage but an interesting answer to explain the meanung of "if ()"
    0 e14 Contributor over 10 years ago in reply to D_Hersey
    Don, I do not know why you were pointing out 3-valued logic.  In any case, the C if statement is clearly based on 2-valued logic.
    "C logic can be bypassed as we people have only developed the C"
    If you want to "bypass" C syntax requirements, then you are talking about a new language.
    More practically, you could write your own preprocessor and expand if() statements any way you like.
    How did you wind up with an if() in the first place?  Could you supply a practical example?
  • D_Hersey
    My only motivation in bringing up three-valued logic is a vain attempt to bring something interesting to this thread.
