Code Exchange
Code Exchange
Forum Need Python OpenCV Code Help
Join Code Exchange to participate - click to join for free!
  • Subscribers 50 subscribers
  • Views 2663 views
  • coding
  • troubleshooting
  • python
  • help
  • python 3
  • Code Exchange
  • opencv
  • code
  • error
braedan
braedan over 9 years ago
Hello Element14 Community!
     This past week I have been revisiting python 3(.5) with OpenCV 3(.2.0 + contrib) on my Windows 10 PC. However I am working on an basic augmented reality application and i have been trying to use OpenCV's ArUco markers module. So far the documentation of this module with OpenCV has been very challenging to understand and is only explained in C/C++. So after a couple days of research and several educated guesses I figured out some of the basic usage for the module and got it to where it is able to identify the marker, highlight it and then calculate the Pose of the marker and draw its axes in a three dimensional space. However that is as far as i could get on my own with my very limited knowledge of the terminology of this module and OpenCV. I am currently having a few issues with my Python code. For one, my code is only able to draw one markers axis with out giving me a error message:
Traceback (most recent call last):
  File "C:\Users\bdogk\Desktop\OpenCV\Augmented Reality - v2.py", line 34, in <module>
    aruco.drawAxis(frame, mtx, dist, rvec, tvec, 0.1) #Draw Axis
cv2.error: D:\Build\OpenCV\opencv-3.2.0\modules\calib3d\src\calibration.cpp:599: error: (-5) Rotation must be represented by 1x3 or 3x1 floating-point rotation vector, or 3x3 rotation matrix in function cvProjectPoints2
The program works fine with one marker. How can I have my program work for multiple markers? I hashed out the drawAxis function in my code and it worked and highlighted both markers. Here is my full code:
import numpy as np
import cv2
import cv2.aruco as aruco
cap = cv2.VideoCapture(0)
with np.load('webcam_calibration_output.npz') as X:
    mtx, dist, _, _ = [X[i] for i in ('mtx','dist','rvecs','tvecs')]
while(True):
    ret, frame = cap.read()
    # operations on the frame come here
    gray = cv2.cvtColor(frame, cv2.COLOR_BGR2GRAY)
    aruco_dict = aruco.Dictionary_get(aruco.DICT_6X6_250)
    parameters =  aruco.DetectorParameters_create()
    '''    detectMarkers(...)
        detectMarkers(image, dictionary[, corners[, ids[, parameters[, rejectedI
        mgPoints]]]]) -> corners, ids, rejectedImgPoints
    #lists of ids and the corners beloning to each id
    corners, ids, rejectedImgPoints = aruco.detectMarkers(gray, aruco_dict, parameters=parameters)
    font = cv2.FONT_HERSHEY_SIMPLEX #font for displaying text (below)
    if ids != None:
        rvec, tvec = aruco.estimatePoseSingleMarkers(corners, 0.05, mtx, dist) #Estimate pose of each marker and return the values rvet and tvec---different from camera coeficcients
        (rvec-tvec).any() # get rid of that nasty numpy value array error
        aruco.drawDetectedMarkers(frame, corners) #Draw A square around the markers
        ###### DRAW ID #####
        cv2.putText(frame, "Id: " + str(ids), (0,64), font, 1, (0,255,0),2,cv2.LINE_AA)
    else:
        ##### DRAW "NO IDS" #####
        cv2.putText(frame, "No Ids", (0,64), font, 1, (0,255,0),2,cv2.LINE_AA)
    # Display the resulting frame
    cv2.imshow('frame',frame)
    if cv2.waitKey(1) & 0xFF == ord('q'):
        break
# When everything done, release the capture
cap.release()
cv2.destroyAllWindows()
I also plan on displaying images over the markers but i dont know how to get the coordinates of the markers center, help? Any links or information would be greatly appreciated! Thank you!
P.S. The marker i have been using is attached to this post.
  • tutin
    0 tutin over 8 years ago
    Hi Braedan,
    I'm fairly new to OpenCV and found this post of yours. I wanted to know the same, how do I find the coordinates of the markers to augment the marker with an image for starters. Please let me know if you did find a way to do that?
    Thanks in advance!
  • joian11
    0 joian11 over 7 years ago
    try this bro.. I'm still  working in the pose estimation but at least i took out the multiple marker problem.
    if np.all(ids is not None):
            zipped = zip(ids,corners)
            ids, corners = zip(*(sorted(zipped)))
            print(len(ids[0]))
            ret = cv2.aruco.estimatePoseSingleMarkers(corners,10,camera_matrix,camera_distortion)
            rvec, tvec = ret[0][0,0,:], ret[1][0,0,:]
            frame = cv2.aruco.drawDetectedMarkers(frame, corners)
            cv2.aruco.drawAxis(frame, camera_matrix, camera_distortion,rvec, tvec,10)
        else:
            cv2.putText(frame,"no id", (0,20),cv2.FONT_HERSHEY_SIMPLEX,0.7,(0,255,0),2)
