Code Exchange
Code Exchange
Forum Python Code help
Join Code Exchange to participate - click to join for free!
  • Subscribers 50 subscribers
  • Views 1018 views
  • Code Exchange
Python Code help
I'm having trouble with a Python code I'm writing. It is for a personal sleep time announcer.
print ('Hello, I am the Sleep Tight program, What is your name?')
myName= input ()
print('It is nice to meet you, ' + myName)
myAge = int(raw_input ('What is your age?'))
if myAge int(<=13)
    print (myName + ', your recommended time of sleep you should get at your age is 9 hours!')
elif myAge int(<=20)
   print (myName + ', your recommended time of sleep you should get at your age is 8 hours!')
else myAge int(>=26)
    print (myName + ', your recommended time of sleep you should get at your age is 7.5 hours!')
I'm having a syntax issue with the highlighted section. Specifically, here!
Please help if you can!
    0 michaelkellett over 12 years ago
    Hello Brandon,
    Try this:
    myName= input ()
    myAge = int(input ('What is your age?'))
    if int(myAge) <= 13:
    elif int(myAge) <=20:
    else:
    I used Python3 so the myAge line uses input because there is no raw_input in P3 but you can use it in P2
    and you don't need the int(...) round myAge (beacuse it is an int already) but I left them in to show you where they should have gone to get correct syntax.
  • dwinhold
    0 dwinhold over 12 years ago in reply to michaelkellett
    Hello Brandon,
    Michael is correct in the code correction.
    A correction he also made was:
    From
    else myAge int(>=26):
    (This part is incorrect as the statement should be also "elif" but then it won't display ages 21 to 25)
    Changed to
    else:
    (This way it includes every number with the exception of the first 2 statements.)
    Keep up the programming Brandon, your doing great
    0 e14 Contributor over 12 years ago in reply to michaelkellett
    Thank you so much, that fixed my problem.
    I'm brainstorming other ways I can build on this program. Would python be able to interact with real time or do I have to build an internal code for it to work off of. Say, a curfew code (or alarm time)?
    I like your idea.
