Code Exchange
Code Exchange
Forum do you have experience using a Linux serial port as C++ stream
Join Code Exchange to participate - click to join for free!
  • Subscribers 48 subscribers
  • Views 859 views
Jan Cumps
Jan Cumps over 2 years ago
I'm trying to use a Linux serial port (say /dev/ttyx) as a sting stream in C++. Just like std::cout is used.
Do you have experience with it, or do you know a decent example?
  • vmate
    vmate over 2 years ago +1
    Threw something together quick, I didn't have time to test it, but give it a try: https://gist.github.com/03vmate/dbd3d423bc033367ae24faa6a6616860 Use it like this: SerialStream serial( "/dev/ttyX…
    shabaz over 2 years ago
    Interesting question. I've not worked in this area, and don't have an example. However, I saw this:
    https://www.nuget.org/packages/crozone.SerialPorts.LinuxSerialPort
    It's quite old code. But am wondering if there is useful stuff there that could be resurrected as a serial port class with stream methods for accessing.
    EDIT: forget that. I just peeked at the code, it's C# : (
    EDIT 2: Looks like Qt supports streaming access: https://doc.qt.io/qt-6/qserialport.html
    Don't know if you wish to add that much middleware to your app though.
    There are other serial port stream implementations but they seem to be in other languages like Java : (
  • vmate
    Use it like this:
    SerialStream serial("/dev/ttyX", 9600);
    // Write a string to the serial port
    serial << "AT\n\r";
    // Read a line from the serial port
    std::cout << "Response: " << serial << std::endl;
    // Read a line, in a different way
    std::string response;
    serial >> response;
    std::cout << "Response: " << response << std::endl;
    Jan Cumps over 2 years ago in reply to vmate
    That looks very promising.
    I found something that I will also test out: https://stackoverflow.com/a/24992028
    #ifndef DEVTTY
    #define DEVTTY "con"    // on Windows
    // #define DEVTTY "/dev/tty" // on Linux/MacOS
    #endif
    using namespace std;
    int main()
       cout << "DEVTTY = " << DEVTTY << endl;
       printf("Print[f]ed to stdout.\n");
       fprintf(stdout, "Print[f]ed to stdout.\n");
       cout << "Printed to std::cout" << endl;
       fprintf(stderr, "Print[f]ed to stderr.\n");
       cerr << "Printed to std::cerr" << endl;
          // C, stdio version
          FILE* fd = fopen(DEVTTY, "w");
          fprintf(fd, "Printed to \"%s\"\n", DEVTTY); // will not be redirected
          fclose(fd);
          // C++, fstream version
          std::ofstream ofs(DEVTTY);
          ofs << "Printed via std::ofstream to \"" << DEVTTY << "\"" << endl; // will not be redirected
       return EXIT_SUCCESS;
