Code Exchange
Code Exchange
Forum I wan't to convert pytorch model to ONNX model. I am getting this error while running the following code
Join Code Exchange to participate - click to join for free!
  • Subscribers 48 subscribers
  • Views 960 views
  • python 3
manojroy123
manojroy123 over 2 years ago
import torch
# Load your PyTorch model
model = torch.load('yolov5s.pt', weights_only=False )
model.eval() # Set the model to evaluation mode
Error:-
>>> %Run convertor.py
Traceback (most recent call last):
File "C:\Users\manojroy\Desktop\CircuitDigest\AssistiveTechForBlind\SIPEED_DEVELOPMENT_BOARD\nncase\ncc_win_x86_64\convertor.py", line 4, in <module>
File "C:\Users\manojroy\AppData\Roaming\Python\Python310\site-packages\torch\serialization.py", line 1097, in load
return _load(
File "C:\Users\manojroy\AppData\Roaming\Python\Python310\site-packages\torch\serialization.py", line 1525, in _load
result = unpickler.load()
File "C:\Users\manojroy\AppData\Roaming\Python\Python310\site-packages\torch\serialization.py", line 1515, in find_class
return super().find_class(mod_name, name)
ModuleNotFoundError: No module named 'models'
Can Anyone help me in solving this error.
    michaelkellett over 2 years ago in reply to manojroy123 +1
    I don't have access to any of the hardware or software you are playing with. But you do. You have an error message which gives you some clues - so you have to follow them. If the code is open source it…
    Well, is there a module called models at the specified path ?
  • manojroy123
    manojroy123 over 2 years ago in reply to michaelkellett
    Where is it.
    I don't have access to any of the hardware or software you are playing with. But you do. You have an error message which gives you some clues - so you have to follow them. If the code is open source it shouldn't be too hard. You will probably need to understand the format of the file 'yolov5s.pt'.
  • javagoza
    javagoza over 2 years ago
    torch.load() requires model module in the same folder · Issue #3678 · pytorch/pytorch (github.com)
