Code Exchange
Code Exchange
Forum how to solve this error for nncase
Join Code Exchange to participate - click to join for free!
  • Subscribers 47 subscribers
  • Views 728 views
  • nn case
manojroy123
manojroy123 over 2 years ago
  • battlecoder
    battlecoder over 2 years ago
    From what the message says, the framework doesn't support Sigmoid operations. However I looked into the repository for nncase (github.com/.../nncase) and it shows that sigmoid is supported, so maybe you are using an older version of nncase?
  • bidrohini
    bidrohini over 2 years ago
    "Fatal: Not supported ONNX opcode: Sigmoid". This means that the tool ncc (the Nncase compiler) does not support the Sigmoid operation in your ONNX model. Replace the Sigmoid operation with an equivalent or supported operation that Nncase can handle.You can try modifying your model to use a different activation function, or preprocess the model using a tool like ONNX Graph Surgeon (GS) to remove or replace unsupported nodes.
