Code Exchange
Code Exchange
Forum testing C++ object copy vs move vs pass-on
Join Code Exchange to participate - click to join for free!
  • Subscribers 48 subscribers
  • Views 263 views
  • c++
Jan Cumps
Jan Cumps 11 months ago
I'm testing what constructs generate object creation, copy, move, or just pass-on. This post is a log of test code, trials, errors.
Test classes
#include <iostream>
#include <array>
#include <string>
template <class T> struct result {
    result() {        // default constructor
        std::cout << "result<T> constructor\n";
    T check;
    constexpr explicit operator bool() const noexcept { return static_cast<bool>(check); }
struct bool_class{
    bool_class() { std::cout << "bool_class constructor\n"; }                                   // default constructor
    bool_class(const bool_class& other) { std::cout << "bool_class copy constructor\n"; }       // copy constructor
    bool_class(bool_class&& other) noexcept { std::cout << "bool_class move constructor\n"; }   // move constructor
    bool_class& operator =(const bool_class& other) {                                           // copy assignment operator
        std::cout << "bool_class copy assignment operator\n";
        return *this;
    bool_class& operator = (bool_class&& other) noexcept {                                      // move assignment operator
        std::cout << "bool_class move assignment operator\n";
        return *this;
    constexpr explicit operator bool() const noexcept{ return true; }                           // status return, obviously test code
Test functions (object factory and similar)
using bool_result = result<bool_class>;
bool_result get_bool_result() { // factory method
    bool_result br; // calls default constructor and result<T> constructor
    return br;
bool_result get_bool_result(bool_class& bc) {
    br.check = bc;  // calls copy assignment operator
    return br;
bool_result get_bool_result(bool_class&& bc) {
    br.check = std::move(bc);   // calls move assignment operator
    return br;
bool_result& get_bool_result(bool_result& br) { // calls nothing, zero cost
    return br;
bool_result&& get_bool_result(bool_result&& br) { // calls nothing, zero cost
    return br;
Test code
int main() {
    if ( auto&& [check] = get_bool_result()) {   // calls default constructor inside the function
        std::cout << "success\n";
        std::cout << (bool)check << "\n";
        bool_class a = check;                   // calls copy constructor
        // bool_class&& b = check;              // invalid
        bool_class c = std::move(check);        // calls move constructor
        bool_class&& d = std::move(check);      // calls nothing
        bool_class e(check);                    // calls copy constructor
        // bool_class&& f(check);               // invalid
        bool_class g(std::move(check));         // calls move constructor
        bool_class&& h(std::move(check));       // calls nothing
        bool_class i = a;                       // calls copy constructor
        // bool_class&& j = a;                  // invalid
        bool_class k = d;                       // calls copy constructor
        // bool_class&& l = d;                  // invalid
        bool_class m = std::move(a);            // calls move constructor
        bool_class&& n = std::move(a);          // calls nothing
        bool_class o = std::move(d);            // calls move constructor
        bool_class&& p = std::move(d);          // calls nothing
        a = check;                              // calls copy assignment operator
        d = check;                              // calls copy assignment operator
        e = check;                              // calls copy assignment operator
        g = std::move(check);                   // calls move assignment operator
        h = std::move(check);                   // calls move assignment operator
        std::array<bool_class,1> ar_a;          // calls copy constructor
        ar_a[0] = a;                            // calls copy assignment operator
        ar_a[0] = d;                            // calls copy assignment operator
        ar_a[0] = std::move(a);                 // calls move assignment operator
        ar_a[0] = std::move(d);                 // calls move assignment operator
        std::array<bool_class,1> ar_b = {a};                // calls copy constructor
        std::array<bool_class,1> ar_c = {check};            // calls copy constructor
        std::array<bool_class,1> ar_d = {std::move(a)};     // calls move constructor
        std::array<bool_class,1> ar_e = {std::move(check)}; // calls move constructor
        if ( auto&& [check] = get_bool_result(a)) {}            // calls copy assignment operator
        if ( auto&& [check] = get_bool_result(std::move(a))) {} // calls move assignment operator
        if ( auto&& [check] = get_bool_result(br)) {}            // calls nothing, zero cost
        if ( auto&& [check] = get_bool_result(std::move(br))) {} // calls nothing, zero cost
I documented the pieces of code that either called a constructor or an assignment operator. Both use some resources (just like creating or assigning to a variable cost something).
Some constructs have a comment // calls nothing. These don't use resources (no memory, cpu time, binary code size).
Requires GCC 15
