Code Exchange
Code Exchange
Files SK9822 LED Datasheet.pdf
Join Code Exchange to participate - click to join for free!
  • Next
  • Previous
SK9822 is a two-wire transmission channel three (RGB) driving intelligent control circuit and the light emitting circuit in one of the LED light source control. Products containing a signal decoding module, data buffer, a built -in constant current circuit and RC oscillator; CMOS, low voltage, low power consumption; 256 level grayscale PWM adjustment and 32 brightness adjustment; use the double output, Data and synchronization of the CLK signal, connected in series each wafer output action synchronization.
e14 Contributor
e14 Contributor
  • 1 Jun 2016
  • 15 Downloads
  • newstar-ledstrip
    newstar-ledstrip over 8 years ago
    Maybe you can try APA107 LED
    “As we measured: This is what we found out:
    The red led is less bright, so the RGB balance is now more ( green-blue) than before.
    The led heats less. !
    We think that the logarithmic curve of the APA107 starts more logic in the beginning:
    The old sk9822 gave nearly NO intensity in the very beginning. (This gave no nice display)
    Now there is some small brightness in the beginning of the APA107 curve. What is very good.”
    APA107 is cheaper than SK9822, everything is more good than SK9822
  • newstar-ledstrip
