Code Exchange
Code Exchange
Documents need help with pull up on input
Join Code Exchange to participate - click to join for free!
  • Author Author: joetrotter
  • Date Created: 15 Feb 2017 3:09 PM Date Created
  • Last Updated Last Updated: 6 Oct 2021 9:02 PM
  • Views 930 views
I am using the gertboard and wiringPi ,and trying to figure out the buttons. The program reads the low when the pull is pushed, but when not pushed, the input is acting as if it is floating and reading random HIGH and LOW. Im a teacher, new to RaspberryPi, beginner  programmer, and am trying to further my knowledge of C. Any help is appreciated. My code is:
#include <wiringPi.h>
#include <stdio.h>
#include <math.h>
#include <time.h>
int main(void)
wiringPiSetupGpio();
pinMode(25,INPUT);
pullUpDnControl(25,PUD_UP);
pinMode(17,OUTPUT);
pinMode(24,OUTPUT);  //if these unused i/o left not set up. they follow GPIO 17 for some reason
digitalWrite(24,LOW);
pinMode(23,OUTPUT);
digitalWrite(23,LOW);
pinMode(22,OUTPUT);
digitalWrite(22,LOW);
pinMode(21,OUTPUT);
digitalWrite(21,LOW);
pinMode(18,OUTPUT);
digitalWrite(18,LOW);
pinMode(15,OUTPUT);
digitalWrite(15,LOW);
int x=0;
while(x<20)
if (digitalRead(25)==LOW)
printf("pushed LED ON, %i\n",x);
digitalWrite(17,HIGH);
while (digitalRead(25)==LOW)
if (digitalRead(25)==HIGH)
printf("not pushed LED OFF , %i\n",x);
digitalWrite(17,LOW);
while (digitalRead(25)==HIGH)
x++;
return 0;
    mcb1 over 9 years ago
    joetrotter
    I'd suggest removing these lines and seeing what happens.
    These will have you stuck and not contnuing the loop.
    As the loop runs it checks if Pin25 is LOW or HIGH and does what it needs to.
    A comparison would be sending two pupils to a door and asking one is the Door OPEN, and the other is the Door CLOSED
    versus sending them and telling them to stay while it is OPEN or CLOSED.
    Outputs should only change when told to.
    So there should be no need to do anything else.
    joetrotter
