Code Exchange
Code Exchange
Documents i have made this code for receive string and store it into an array then comparing it to perform task but its not working.help me to get eny sollution
Join Code Exchange to participate - click to join for free!
  • Author Author: gk.rajatc
  • Date Created: 26 May 2020 10:04 AM Date Created
  • Last Updated Last Updated: 6 Oct 2021 10:22 PM
  • Views 945 views
#ifndef F_CPU
#define F_CPU 8000000UL // 16Mhz clock speed
#endif
#include <avr/io.h>
#include <util/delay.h>
#include <string.h>
//#define USART_BAUDRATE 9600
#define BAUD_PRESCALE (((F_CPU / (USART_BAUDRATE * 16UL))) -1)
#define LED_ON  PORTD |= (1<<PIND6);
#define LED_OFF6  PORTD &= ~(1<<PIND6);
volatile unsigned char string[15],x,i =0;
volatile char Reply_CallReady[15]="apple";
volatile char C;
volatile char data[10];
void UART_init(long USART_BAUDRATE)
UCSRB |=(1<<RXEN)|(1<<TXEN)|(1<<RXCIE);//TURN ON TRANSMISSION AND RECEPTION.
UCSRC |=(1<<URSEL)|(1<<UCSZ0)|(1<<UCSZ1);//USE 8 BIT CHARACTER.
UBRRL |=(BAUD_PRESCALE);//LOAD LOWER 8 BITS OF THE BAUD RATE VALUE.
UBRRH |=(BAUD_PRESCALE>>8);//LOAD UPPER 8 BIT.
unsigned char UART_Rxchar()
while((UCSRA & (1<<RXC))==0);//wait till data is received.
return(UDR);//RETURN THE BYTE.
void UART_Txchar(char ch)
while (!(UCSRA & (1<<UDRE)));//wait for empty transmit buffer.
UDR=ch;
void UART_sendstring(char *str)
unsigned char j=0;
while(str[j]!=0)     // send string till null.
UART_Txchar(str[j]);
j++;
void lcd_cmd(char cm)
char a=cm;
PORTA=a;
PORTB=(0<<PD0)|(0<<PD1)|(1<<PD2);
_delay_ms(50);
PORTB=(0<<PD0)|(0<<PD1)|(0<<PD2);
void lcd_data(char dat)
char b=dat;
PORTA=b;
PORTB=(1<<PD0)|(0<<PD1)|(1<<PD2);
_delay_ms(50);
PORTB=(1<<PD0)|(0<<PD1)|(0<<PD2);
_delay_ms(50);
unsigned char *UART_RX_STR(x)
while (x != '\0')
string[i++] = x;
return string;
ISR(USART_RXC_vect)
C=UDR;
int main()
DDRB=0xFF;
DDRA=0xFF;
UART_init(9600);
while(1)
C=UART_Rxchar();
x=C;
if (strcmp(string,Reply_CallReady) ==0)
LED_ON;
else
LED_OFF6;
  • Code Exchange
    shabaz over 6 years ago
    Hi Rajat,
    It isn't easily readable, please can you edit the discussion and use the code syntax highlighting tool, and paste in code so that tabs or spaces are intact?
    Information on how to find the syntax highlighting tool is here:
    How to Ask Questions using the Create Discussion tool
