Connector Technology & Design
Blog SKEDD Connectors an Introduction.
Join Connector Technology & Design to participate - click to join for free!
  • Author Author: karthickiot
  • Date Created: 8 Sep 2020 8:59 AM Date Created
  • Views 1246 views
  • pcb plug-in connectors
  • crimp connections
  • skedd connectors
  • phoenix contact
karthickiot
karthickiot
8 Sep 2020
Soldering and press-fit was yesterday but the future is SKEDD’s direct plug-in technology. The SKEDD contacts are produced using a stamping technology. They can be designed with two or four arms (in folded design). Whereas press-fit technology with solid pins results in VIA deformation, and press-fit technology with flexible pins results in pin deformation, direct plug-in technology with SKEDD contacts results in no deformation.
Contact requirements for SKEDD technology include:
  • Easy and simple plug-in process
  • Vibration-proof connection
  • Multiple times pluggable
  • Reversible connection
  • Fitting accuracy
More details about the connector pins and PCB connectors can be see in the SKEDD and purchase from Phoenix Contact
A short video is shown to use the connectors in PCB layout.
SKEDD connectors are easy to use to plug or unplug on the PCB board they have locking pins, Wire can be connected to connectors by crimp or push-in contacts instead of soldering or screwing to terminals. It is also easy to remove the wires from connectors by opening the locks. The locking system is available for wires and connectors is the advantage to use them in our next designs. their are various types  of connections from low to high range voltage, current, frequency applications.
