Connector Technology & Design
Forum Robust micro USB B receptacle?
  • Answers 3 answers
  • Subscribers 128 subscribers
  • Views 1613 views
genebren
genebren over 8 years ago
Greetings,
Has anyone had any good success with finding a robust micro USB B receptacle I have used an Amphenol FCI  10118194-0001LF10118194-0001LF on several different designs but these tend to be a little flaky They make intermittent connections(even when just using+5V connections Even the slightest movement causes a disconnect(the solder joints on the pads look fine I originally started using these for their through hole anchors
Gene
    shabaz over 8 years ago in reply to genebren +3 suggested
    Hi Gene, I find them really awkward (because my hot-air tool is awful). It might be possible to do it with a dab of solder paste on the pads before placing the part down, and then poking a fine iron tip…
  • luislabmo
    luislabmo over 8 years ago +2 verified
    Hello genebren , I have tried these GCT USB3076-30-A GCT USB3076-30-A a couple of times, have been decent so far. Luis,
    genebren over 8 years ago +2
    Thanks shabaz and luislabmo for these nice options. I have wondered if part of my problem with the Amphenol FCI part was my hand soldering. What methods have you used with the connectors that you have…
  • luislabmo
    0 luislabmo over 8 years ago
    Hello genebren,
    I have tried these GCT USB3076-30-AGCT USB3076-30-A a couple of times, have been decent so far.
    Luis,
    0 shabaz over 8 years ago
    Hi Gene,
    I used this Hirose one on a few boards, like you I chose the ones with anchors:
    ZX62D-B-5P8(30)ZX62D-B-5P8(30)
    It has a slightly wider landing pattern than the one you're using though.
    0 genebren over 8 years ago
    Thanks shabaz and luislabmo for these nice options.  I have wondered if part of my problem with the Amphenol FCI part was my hand soldering.  What methods have you used with the connectors that you have suggested?
    Gene
  • luislabmo
    0 luislabmo over 8 years ago in reply to genebren
    Hello genebren,
    Since I only use them for my personal projects (one or two every once in a while), I use both Hot air and a soldering iron:
    • First, I solder all the parts with a hot-air gun (I don't own a hot-air rework station), for this part I don't use hot-air on the anchors.
    • Then, I use a soldering iron to solder the anchors (which are through hole -not very long-). I just make sure to fill-in the hole with solder, and I try to keep a blob of solder on both sides of the PCB -depending on the width of the PCB-, this ensures that will be durable vs you know..... users image
    Here you can find the footprint for it https://www.snapeda.com/parts/USB3076-30-A/Global%20Connector%20Technology/view-part/
    On a personal note: not every fab can do plated slots, so I made my own package with through-hole pads.
    Good luck!
    Luis
    0 shabaz over 8 years ago in reply to genebren
    Hi Gene,
    I find them really awkward (because my hot-air tool is awful). It might be possible to do it with a dab of solder paste on the pads before placing the part down, and then poking a fine iron tip into the area so that the paste melts. It could be easier than trying to insert wire solder in there. I have used a reflow oven for them, but I don't like doing that just for a single connector, so I need to revisit the hot-air method, or something else..
