Connector Technology & Design
Forum 3M连接器的分类有哪些?
  • Subscribers 127 subscribers
  • Views 1165 views
3M连接器的分类有哪些?
糖葫芦mm
糖葫芦mm over 15 years ago
3M连接器的分类有哪些?
  • 呵呵我
    呵呵我 over 15 years ago
    3M连接器
    一:产品类型
    1:I/O(输入输出)连接器----------------Input/Output Connectors
    2:存储互连-----------------------------Storage Interconnects
    3:接口对接口(PCB板)------------Board-to-Board Connectors
    4:背板连接器---------------------------------Backplane Connectors
    5:线缆------------------------------------------Cable/Wire
    6:存储卡--------------------------------------Memory Card Headers
    7:线对板(线板)连接器-----------------Wire-to-Board Connectors
    8:IC插座--------------------------------------IC Sockets
    9:线对线连接器----------------------------Wire-to-Wire Connectors
    10:线缆组件-------------------------------- Cable Assemblies
    二:具体类型简介
    I/O(输入输出)连接器---------Input/Output Connectors
    1:Delta Ribbon (D Ribbon) Connectors
    2:Delta Sub (D Sub) Connectors
    3:  IEEE 1394 2 mm Connectors
    4:  Mini Delta Ribbon (MDR) Connectors
    5:  Mini-Clamp Connectors6:  Shielded Compact Ribbon (SCR) Connectors
    7:  Shrunk Delta Ribbon (SDR) Connectors
    8:  Power Clamp Connectors
    9:  Mounting Hardware
    1:Mini Serial Attached SCSI (miniSAS) Connectors (SCSI串行总线结构)2:Serial Advanced Technology Attachment (SATA) Connectors(SATA总线结构)
    3:  Serial Attached SCSI (SAS) Connectors(SCSI串行总线结构)总结:此类连接器主要用于硬盘等存储设备互连
    接口对接口(PCB板)------Board-to-Board Connectors
    1:Compression Connectors
    2:Connector Accessories
    3:  Headers (Plugs)
    4:  Hermaphroditic Connectors
    5:  Sockets (Receptacles)
    背板连接器--------------------------Backplane Connectors
    1:CompactPCITm (CP2) Connectors
    2:DIN Connectors, Wiremount
    3:  DIN Connectors
    4:  FuturebusTm (2-FB) Connectors
    5:  Hard Metric (HM) Connectors
    (压接连接器)Hard Metric连接器公头及母头连接器能在有限空间中容纳大量信号引脚,便于节省PCB成本。信号引脚多的特点可使其适用于速度更高的产品。
    6:  High Density Connectors (HDC)
    7:High Speed Hard Metric (HSHM) Connectors
    线缆------------------------------------Cable/Wire
    1:Cable Accessories
    2:Cable Guide
    3:  Color Coded Flat Cable
    4:  Cable Processing Tools
    5:  Extended Flex Life Cable
    6:  Ground Plane Cable
    7:Jacketed Flat Cable
    8:Pleated Foil Cable
    9:Power Flat Cable
    10:Round Conductor Flat Cable
    11:Round Shielded/Jacketed Cable, Discrete
    12:Round Shielded/Jacketed Flat Cable
    13:Shielded/Jacketed Flat Cable
    14:Twisted Pair Flat Cable
    存储卡---------------------------------Memory Card Headers
    1:Card Connector, microSDTm
    2:Card Connector, Surfacemount SDTm
    3:CompactFlashTm (CF) Headers
    4:PC Card Header
    总结:主要用于存储设备;像数码相机,手机等消费电子类产品
    线对板(线板)连接器------------Wire-to-Board Connectors
    1:Card Edge  Connectors
    3:  Headers (Plugs)
    4:  Hermaphroditic Connectors (雌雄同体)
    5:  PCB Connectors
    6:  Sockets (Receptacles)
    1:DIP Screw Machine Sockets - DISCONTINUED
    2:DIP Stamp & Form Sockets
    3:  Pin Grid Array (PGA) Sockets
    4:  Plastic Leaded Chip Carrier (PLCC) Sockets
    5:  Single In-Line Package (SIP) Sockets
    6:  TextoolTm Leadless Chip Carrier (LCC) Sockets
    总结:针对不同封装的IC插座
    线对线连接器------------ --------------Wire-to-Wire Connectors
    1:Headers (Plugs)
    2:Hermaphroditic Connectors
    3:  Sockets (Receptacles)
    1:Cable Guide
    2:Industry Standard Cable Assemblies
    3:  Low Voltage Differential Signaling/Transition Minimized Differential Signaling(LVDS/TMDS) Cable Assemblies
    4:  Mini Serial Attached SCSI (miniSAS) Cable Assemblies
    5:  Monosignal (mini-coaxial) Cable Assembly  同轴
    6:  Serial Advanced Technology Attachment (SATA) Cable Assemblies
    7:Shrunk Delta Ribbon (SDR) Cable Assemblies
    8:Shielded Controlled Impedence (SCI) Cable Assemblies
    9:Pleated Foil (PFC) Jacketed Flat Cable Assemblies
    10:Molded-On Flat Ribbon Cable Assemblies, .100", 2 mm11:Mini Delta Ribbon (MDR) Cable Assemblies12:Micro Coaxial Cable Assemblies
