Embedded and Microcontrollers
Blog PCB designing with Autodesk Fusion 360
  • Author Author: embeddedguy
  • Date Created: 18 Jan 2025 4:32 AM Date Created
  • Views 13211 views
  • Comments 25 comments
  • pcb design
  • autodesk
embeddedguy
embeddedguy
18 Jan 2025
Most of us who like to make PCBs are familiar with Eagle CAD drawing software. I started using EAGLE when it was taught in my university during my bachelors degree. At that time I did not even realize that PCB designing skills would be very useful to me in the future even after years of passing out.
But some time ago Autodesk announce that it will discontinue EAGLE from somewhere in the mid of 2027. That was a bit shocking news for me who used EAGLE to design some PCBs.
But recently I gave found that Autodesk Fusion 360 for personal use is cloud-based development platform also to design PCBs, with similar features as EAGLE has. It is free to use for personal use and has limited features. BTW the full feature version comes at $ 85/month or $ 768/year plan.
For now, I just give it a try to Fusion for personal user. Here is a 2-layer PCB layout design. I personally found Fusion 360 for PCB easy to use and it has some nice features that helps developer to create complex PCB.
What do you think? Let me know in the comments,
  • ruch
    ruch over 1 year ago
    I am stuck in my fusion design - I have 2 pcb boards designed in fusion360. From that design how to generate the drill legend or drill table? Also want to generate dxf file from Run ULP feature infusion - how to do that? because it asks for some drillpan.ulp file. Where and ow to get .ulp file? Thank You so much for help and responses.
  • embeddedguy
    embeddedguy over 1 year ago in reply to Andrew J
    I don't have an idea what happens if the subscription ends. But for sure you can view it at least that is my understanding. Then as you said if you don't want to pay for yearly, I think there is monthly plan as well. just to finish your rest of the PCB if it is not complete.!
  • Andrew J
    Andrew J over 1 year ago in reply to shabaz
    Given the functionality of KiCad it doesn’t make sense to pay £450+ yearly unless you’re a serious user of the tool.  I use it for modelling - I’ve re-created a German Enigma machine in the modelling tool (most of it anyway) and some Bombe parts - and I find it worthwhile currently.  Even so, I don’t think I could commit to that price just for PCB and schematic modelling.
    shabaz over 1 year ago in reply to Andrew J
    Hi Andrew,
    As far as I understand, the design is still openable for viewing, but no changes can be saved, without subscribing again, as you say. Still quite a deal-breaker for hobby use, because you might only work on a project on-and-off, and it would get expensive quick to keep paying on the months you wanted to work on the project.
  • Andrew J
    Andrew J over 1 year ago in reply to embeddedguy
    Do you know what happens if you subscribe, create a multi-layer board, then let the subscription lapse?  I’d assume that the schematic/PCB would no longer be editable but can it be viewed?
