Embedded and Microcontrollers
Blog when a mod goes wrong - failed attempt to add an external antenna
  • Date Created: 25 Apr 2021 11:58 AM Date Created
  • Views 3698 views
  • Likes 13 likes
  • Comments 9 comments
25 Apr 2021
Modifications don't always go right.
Yesterday morning I tried to replace the PCB WiFi / BT antenna on a Avnet SmartEdge with an external one.
I had to place a fitting connector on a footprint and turn a resistor 90° to route the signal to it.
I got he connector off a launchpad that's no longer supported.
That wasn't hard, although it took a decent time to heat up the big ground plane.
The drama occurred when I tried to unsolder the tiny resistor with a hot air pencil.
The trace between the lower side of the resistor and the ceramic filter FL1 underneath it ripped off completely.
Various attempts to try and scrape a little bit of track from under the filter failed. So I had to remove it with hot air.
Then try to create my own little trace from underneath it.
Long story short, it didn't work.
I managed to restore all electronic connections (I buzzed everything through, but never got a BT or WiFi signal out).
I also tied to restore the original route with a tiny patch wire made with a transformer (enamel tactically removed at the right spots) wire.
It never worked again.
Tried this morning with fresh energy - and daylight - but again no success.
As you can see, my very last attempt - when I knew it was a lost case but gave it a shot anyway - turned the part of the board where the PCB antenna is, charred.
Officially not fixable anymore, I adapted the overlay to disable wifi and BT. I'm using wired network now.
On the + side, it gives me a chance to show you the underside of the PCB:
  • aspork42
    aspork42 over 5 years ago +5
    Dang - so close. It wasn't for a lack of trying, so kudos for that. At least you tried. When I attempt repairs on on others electronics, I always warn them that “it may get fixed; it may never work again…
  • colporteur
    colporteur over 5 years ago +4
    Bad luck. Impressive, you have the skills to make the repair attempt in the first place. Our company outsourced much of this work. You didn't by any chance work on a phase array bridge that connected antennas…
    Jan Cumps over 5 years ago in reply to colporteur +4
    colporteur wrote: .... You didn't by any chance work on a phase array bridge that connected antennas to a instrument landing system (ILS)? Did you get disappointing results?
  • aspork42
    Dang - so close. It wasn't for a lack of trying, so kudos for that. At least you tried. When I attempt repairs on on others electronics, I always warn them that “it may get fixed; it may never work again” for this exact reason. A simple mistake could make it completely uneconomical to repair any further. Imagine bumping a BGA after you have heated a board up...
    • Vote Up +5 Vote Down
    Jan Cumps over 5 years ago in reply to aspork42
    I've been successful with comparable mods. What bit me is that the resistor you have to move, is on a track that's maybe 2 mm long. It just came off with the resistor, even though the solder had melted.
    I used a hot air pencil at 350 °C with a sea of flux, and the board pre-heated at 120 °C. This rarely damages a track or pad.
