Embedded and Microcontrollers
Blog when a mod goes wrong - failed attempt to add an external antenna
  • Date Created: 25 Apr 2021 11:58 AM Date Created
  • Views 3694 views
  • Likes 13 likes
  • Comments 9 comments
25 Apr 2021
Modifications don't always go right.
Yesterday morning I tried to replace the PCB WiFi / BT antenna on a Avnet SmartEdge with an external one.
I had to place a fitting connector on a footprint and turn a resistor 90° to route the signal to it.
I got he connector off a launchpad that's no longer supported.
That wasn't hard, although it took a decent time to heat up the big ground plane.
The drama occurred when I tried to unsolder the tiny resistor with a hot air pencil.
The trace between the lower side of the resistor and the ceramic filter FL1 underneath it ripped off completely.
Various attempts to try and scrape a little bit of track from under the filter failed. So I had to remove it with hot air.
Then try to create my own little trace from underneath it.
Long story short, it didn't work.
I managed to restore all electronic connections (I buzzed everything through, but never got a BT or WiFi signal out).
I also tied to restore the original route with a tiny patch wire made with a transformer (enamel tactically removed at the right spots) wire.
It never worked again.
Tried this morning with fresh energy - and daylight - but again no success.
As you can see, my very last attempt - when I knew it was a lost case but gave it a shot anyway - turned the part of the board where the PCB antenna is, charred.
Officially not fixable anymore, I adapted the overlay to disable wifi and BT. I'm using wired network now.
On the + side, it gives me a chance to show you the underside of the PCB:
  • aspork42
    aspork42 over 5 years ago +5
    Dang - so close. It wasn't for a lack of trying, so kudos for that. At least you tried. When I attempt repairs on on others electronics, I always warn them that “it may get fixed; it may never work again…
  • colporteur
    colporteur over 5 years ago +4
    Bad luck. Impressive, you have the skills to make the repair attempt in the first place. Our company outsourced much of this work. You didn't by any chance work on a phase array bridge that connected antennas…
    Jan Cumps over 5 years ago in reply to colporteur +4
    colporteur wrote: .... You didn't by any chance work on a phase array bridge that connected antennas to a instrument landing system (ILS)? Did you get disappointing results?
    Jan Cumps over 5 years ago in reply to aspork42
    I've been successful with comparable mods. What bit me is that the resistor you have to move, is on a track that's maybe 2 mm long. It just came off with the resistor, even though the solder had melted.
    I used a hot air pencil at 350 °C with a sea of flux, and the board pre-heated at 120 °C. This rarely damages a track or pad.
  • aspork42
    Dang - so close. It wasn't for a lack of trying, so kudos for that. At least you tried. When I attempt repairs on on others electronics, I always warn them that “it may get fixed; it may never work again” for this exact reason. A simple mistake could make it completely uneconomical to repair any further. Imagine bumping a BGA after you have heated a board up...
    • Vote Up +5 Vote Down
    image Did you get disappointing results?
  • colporteur
    Bad luck. Impressive, you have the skills to make the repair attempt in the first place. Our company outsourced much of this work. You didn't by any chance work on a phase array bridge that connected antennas to a instrument landing system (ILS)?
