Embedded and Microcontrollers
DSP Forum 450MHz Shark DSP Dev-kits
  • Replies 13 replies
  • Subscribers 171 subscribers
  • Views 2953 views
  • fram
  • mhz
  • lcd
  • sdram
  • tft
  • mandelbrot
  • spi
  • uart
  • dsp
  • dev
  • sram
  • analog
  • shark
  • kits
Kilohercas
Kilohercas over 12 years ago
Hello, does any one are interested in Analog devices Shark development kit ?
Basically it is ADSP-21489 floating point DSP running at 450MHz ( possible to 700MHz overclock) with all pins connected to header (except single UART for debugging and boot pins for spi flash since i am using dual channel FT2232 for debugging/programing)
I made Labview program that can program external SPI flash with FT2232D  from Labview by using loader file generated inside  Crosscore or VisualDSP++ IDE. This can be very high performance calculation engine for demanding applications. I can do single point DFT with 128 array at 2MHz repetition rate, while ARM Cortex M4 (STM32F407 running 250MHz can only do 50KHz !! )
Here is what Shark DSP can do in native calculation image (Mandelbrot fractal in f32 )
At the moment i have single unpopulated board , but can order more if demand is big. With additional cost i can buy all parts, assemble and ship it as full development kit.
    e14 Contributor over 11 years ago in reply to Kilohercas
    If you prefer to talk in private my email is ealfie _at_ gmail _dot_ com
    do you have a datasheet, manual or something like that?
    e14 Contributor over 10 years ago in reply to Kilohercas
    Hi
    Is it available jet, and what would be the price?
    Ivica
    ivica _at _tsbest _dot _net
  • edsonbrusque
    edsonbrusque over 9 years ago in reply to Kilohercas
    Hello Linas Karpavicius!
    I'm starting a project with SHARC and would like to buy this board.
    Please, email me at edsonbrusque (at) gmail (dot) com.
    Thank you!
