Embedded and Microcontrollers
Embedded Forum Home Fabricating
  • Subscribers 502 subscribers
  • Views 643 views
  • embedded
  • fab
Home Fabricating
Catwell over 16 years ago
Does anyone make their own PCBs at home? If so, share how you do it.
Also, anyone have any experience using a CNC router for circuit printing?
I'm not very fond of chemical baths, acid baths, etc; is there a way to make a PCB without the typical steps? ie: Etching,
  • Thomas
    Thomas over 16 years ago
    Hi Catwell,
    I use strip boards, and for high current power supplies use Strip or sometimes Vero boards.
    You are not fond of chemicals; and you intend to use a CNC router, which you may have at your disposal with the required software(CAD) to convert the PCB layout into scalar. Control the depth of cut, and you have a PCB ready.
    A CNC milling or an engraver may also be used for the same.
    All this, provided you have access to a well equipped toolroom or workshop.
    Happy development.
  • enrico.migchels
    enrico.migchels over 16 years ago
    Hi Cabe,
    CNC millers have some disadvantages also. The milling task is time consuming, you isolate a track by milling a gap and you have to change machine tools. Chemicals are not that bad. About a year ago i asked a company to help me select all necassary machines for a PCB protyping production line and they did not recommend the CNC route. For our situation a traditional chemical bath with streaming water attached was best (and quickest).
    Best regards,
    Enrico Migchels
    Power Conversion Design Engineer
    Heliox B,V,
    Best - The Netherlands
    www.heliox.nl
  • fustini
    fustini over 16 years ago in reply to enrico.migchels
    This popped into my head when I first saw the Subject:, the ultimate in home fabricating - checkout Jeri Ellsworth's home transistor fab lab:
    http://www.flickr.com/photos/jeriellsworth/2835459827/
    For those that have not heard of her, she is super awesome:
    http://lifehacker.com/5480199/macgyver-of-the-day-electronics-hacker-jeri-ellsworth
    She rose to DIY stardom after reverse engineering the C64 and implementing on an FPGA.  The final product fit inside a joystick with a/v out for a TV and sold 70,000 units on QVC.
    Cheers,
    Drew
    http://twitter.com/pdp7
