Embedded and Microcontrollers
Embedded Forum STM32 MCUs Programming
  • Replies 19 replies
  • Subscribers 505 subscribers
  • Views 4782 views
  • stm32f4
  • stm
  • programing
  • arm
  • nucleo
mparmpas122321
mparmpas122321 over 11 years ago
Hello!
I am trying to get started with the programming of STM32 MCUs. I have bought a Nucleo board which has a STM32F411RE MCU on it. I have downloaded the Keil ARM MDK development environment. I have studied the datasheet of the STM32F411RE. I am going to read the Programming Manual but i was just wondering if there are any guides or manuals that can show some stuff to get you started. I would really apreciate it, If anyone has some experience on STM32 - Arm programming and could help me . image
    michaelkellett over 11 years ago in reply to gihu +2
    I had a quick look at their web site and although they only directly support a very limited number of processors it certainly looks worth a try if you need a free tool. If you are wondering why processor…
  • Anonymous-237891
    Anonymous-237891 over 11 years ago +2
    Hi, Keil is a great programm since it support a lot of MCU right out of the box. If I can give you ONE advice: enroll that course https://www.edx.org/course/utaustinx/utaustinx-ut-6-02x-embedded-systems…
  • johnbeetem
    johnbeetem over 11 years ago in reply to D_Hersey +1
    Don Hersey wrote: Please let me generalize this question: What are low/no cost ways to program ARM in the Wintel and Linux contexts that you guys would recommend? Ones that do not turn into a pumpkin…
  • gihu
    gihu over 11 years ago
    Hi Manos
    Is it the official one by ST?
    If yes, try the 'Getting started' document for your board. Probably the easiest way.
    Check this:
    http://www.st.com/st-web-ui/static/active/en/resource/technical/document/user_manual/DM00105928.pdf
    and
    NUCLEO-F411RE STM32 Nucleo development board for STM32 F4 series - with STM32F411RE MCU, 512KB flash memory, TQFP64 pack…
    Any other help you nedd, ask image
    Hope that helps,
    Miguel
    The Keil tools contain many example programs and a "blinky" project for just about everything.
    Try running Blinky on your board and then start tweaking it.
  • D_Hersey
    D_Hersey over 11 years ago
    Please let me generalize this question:  What are low/no cost ways to program ARM in the Wintel and Linux contexts that you guys would recommend?  Ones that do not turn into a pumpkin through code or time limits.
    michaelkellett over 11 years ago in reply to D_Hersey
    There are two good commercial toolsets that I know of, Keil and IAR. Both offer free code size limited versions. I use the Keil toolset which is limited to 16k. I think the IAR limit is the same but you would need to check.  If you are working with ST processors some of the dev boards have a built in debug dongle but if you make your own board you can buy an STLink for about £17.
    Once you want to go over that 16k limit you are into GCC if you want to keep free and the GCC debugging isn't very good (check up on this if it really matters to you because the situation changes.) There are lots of commercial GCC based ARM dev tools, some may have larger code limits before you have to pay - look at Code Red, Raisonance, Rowley.
    If you don't mind being stuck using Atmel's Cortex processors then I think the Atmel Dev Studio is the nicest free tool (slightly dodgy opinion this, because I don't use Atmel processors so haven't used the tools in anger.)
  • johnbeetem
    I've had good luck in the past with CodeSourcery, which has a free "lite" version for both Windows and GNU/Linux.  The most recent one I've used is "Sourcery G++ Lite 2011.03-41 for ARM GNU/Linux" which I use to create BeagleBoard/Bone executables that run on Ångström GNU/Linux.  I've used the Windows version in the past, using Cygwin to provide a good programming environment with GNU tools like "make".
    Basically, Sourcery Lite is GCC compiled to run on a PC but generate code for ARM.  Be sure to select the correct Cortex-M variant for STM.  I use the ARM GNU/Linux version which has the ABI (Application Binary Interface) for GNU/Linux libraries.  For STM, you probably want EABI which I think is the Embedded ABI for bare metal programming.
    Sourcery Lite comes with no support, so you either have to have lots of experience using cross compilers for embedded targets or have a good Google noise filter.
    CodeSourcery was acquired by Mentor Graphics, so Sourcery Lite is now at: http://www.mentor.com/embedded-software/sourcery-tools/sourcery-codebench/editions/lite-edition/
  • mparmpas122321
    mparmpas122321 over 11 years ago in reply to gihu
    I have read these documents. They just give a description of the board and tell you which Environments to install. Nothing about how to program it. Thanks anyway. image
  • mparmpas122321
    mparmpas122321 over 11 years ago in reply to michaelkellett
    Yeah i have seen the blinky project but i can't understand many things from its code. I am completely newbie to ARM processors and they way they are programmed. I have experience some experience with Arduino but it is way too easy to program.
  • gihu
    gihu over 11 years ago in reply to D_Hersey
    I have used CoIDE from Coocox (Free and Open ARM Cortex MCU Embedded Development Tools), it uses GCC compiler.
    I have used with STM32F4 discovery, CoIDE admits ST-Link/V2 so can debug.
    I think it is great, and free!!
  • johnbeetem
    johnbeetem over 11 years ago in reply to mparmpas122321
    Does Blinky have any assembly language or is it all C?  If it's all C, then there's really no need to know anything about the ARM instruction set.  However, you probably need to find STM32 device registers referenced in the code so you can see what their bits do.  Those will be in the technical reference manual for the specific STM32 processor family.  I assume Blinky uses some STM32 header (.h) files that tell your C program where to find device register bits.
    If you are wondering why processor support matters .........
    Modern micro-controllers are complicated with large numbers of on chip peripherals. If the tools "knows" about these then debugging is a much faster and more satisfactory experience. If you are happy with more basic debugging with no peripheral awareness then processor support hardly matters. I do this kind of stuff for a living and I would be very reluctant to do without  a fully peripheral aware debug tool.
    If I ever get time I'd certainly try the Coocox tool on a project where they support the processor.
