Embedded and Microcontrollers
Embedded Forum Issues shortening a USB cable?
  • Subscribers 503 subscribers
  • Views 797 views
Workshopshed
Workshopshed over 10 years ago
For my Dragonboard project I'm repurposing an old USB Webcam and it comes with a rather long cable.
Dragonboard 410c More GPIO
I was wondering if there are any issues with shortening a screened USB cable? It comes with some ferrite beads at both ends. I preume that I'd just replace those on the shorter cable? It's currently about a 1.8m and I intend to bring it down to about 20cm.
  • dwinhold
    dwinhold over 10 years ago +1
    Hi Andy, I have cut down a cable simular to this and re-installed the ferrites at the "camera" end. It worked fine with no issues, another one I did, instead of cutting one end shorter I cut the length…
  • Workshopshed
    Workshopshed over 10 years ago +1
    Thanks again for the re-assurance, as you suspected it worked just fine.
    0 michaelkellett over 10 years ago
    Very unlikely to cause any problems.
  • Workshopshed
    0 Workshopshed over 10 years ago in reply to michaelkellett
    Thanks Michael, it was the ferrites that had me concerned. I was thinking that the data from a camera comes out a quite a high speed and I was worried that the cable was in some way tuned to match.
  • dwinhold
    0 dwinhold over 10 years ago
    Hi Andy,
    I have cut down a cable simular to this and re-installed the ferrites at the "camera" end. It worked fine with no issues, another one I did, instead of cutting one end shorter I cut the length out of the centre and spliced it together leaving the ferrets in place. I had to make sure to re-wrap the foil on each wire after insulating. This saved me re-doing the ferrets.
    Dale
  • Workshopshed
