Embedded and Microcontrollers
Embedded Forum Prevent backfeeding from arduino 5V pin
  • Answers 3 answers
  • Subscribers 505 subscribers
  • Views 1621 views
steve25
steve25 over 9 years ago
Hi all,
I have a problem with my arduino nano board. The 5V pin is backfeeding into my circuit when i plugin my USB cable. My circuit draws way to much current than my USB can supply. So the question is: Is there a way to prevent the backfeeding into my circuit? I already considered using diodes but that would create a voltage drop of 0,7V which is a bit much.
Hope i'l get a response soon!
Steve
  • D_Hersey
    D_Hersey over 9 years ago +1 suggested
    Shottky or Ge?
  • D_Hersey
    0 D_Hersey over 9 years ago
    Shottky or Ge?
  • steve25
    0 steve25 over 9 years ago in reply to D_Hersey
    Thanks for the reply. A Schottky is a good solution because of the low forward voltage. But I think i'l use a transistor. I connect the base to an external power source line. So if the external power source isn't on the transistor is turned off. The 5v pin can't backfeed in this case!
  • steve25
    Noticed i'm losing 0,8 volts by using a transistor... So i decided to go with the Schottky diode (1N5817) which has only a forward voltage of 0,25V at 30mA. That should do the job!
  • awardautomation
    0 awardautomation over 9 years ago
    You could also use a mosfet... They behave like a resistor when on, good ones have very low "on-resistance"
