Embedded and Microcontrollers
Embedded Forum Removing silkscreen from ICs
  • Subscribers 494 subscribers
  • Views 750 views
  • microprocessor
  • microcontrollers
  • microcontroller
Catwell over 16 years ago
What could I use to remove silkscreen labeling from ICs, wafers, and laminates without destroying whatever I am cleaning? This is for no particular reason, just a curiosity.
Cabe
  • ASano
    0 ASano over 16 years ago
    usualy I use the nail polish remover with cloth. this don't destroy the PCB.
  • Catwell
    0 Catwell over 16 years ago in reply to ASano
    Antonino,
    Acetone or MEK, nail polish remover, is an excellent option. I did a little research on it, and it seems like a non destructive choice.
    Anyone try brush on epoxy?
    Cabe
  • WestfW
    0 WestfW over 16 years ago
    I think that most silkscreen inks these days are some sort of epoxy, which means that they're pretty much immune to all but the most extreme of solvents.  IC packages are now frequently laser-etched, so there's no ink to remove at all...  Abrasives still work.
  • WestfW
    0 WestfW over 16 years ago in reply to WestfW
    I did, however, in the process of cleaning the garage, find an old sample of Miller Stephenson's "Conformal Coating Stripper" that claims to remove urethane, epoxy, and some lesser coatings.   I expect "Conformal Coating Stripper" is a nice key phrase; web searches turn up several alternatives.  But I didn't see anything in Newark's catalog...
    http://www.miller-stephenson.com/epoxy_resins_010.htm
  • Catwell
    0 Catwell over 16 years ago in reply to WestfW
    Laser etched is the trend for sure. I suppose I could literally take some material off the top on the chip with abrasives. Hopefully, I will not take too much off.
    Cabe
