Embedded and Microcontrollers
Embedded Forum PLC interfacing to a website
  • Subscribers 502 subscribers
  • Views 827 views
  • 8_bit
  • plc
  • 16_bit
  • microcontroller
Catwell over 16 years ago
I want data from various websites to be available on a PLC network. Can anyone suggest a type of PLC and a way to do this?
The data I want on the network is US Government security warnings, National Weather Service, and some other proprietary sites.
Cabe
    0 e14 Contributor over 16 years ago
    I haven't used PLC's for many years, but I think you need to use some fairly high-end devices with either
    serial of network connection in order to feed them the data. (I suppose that you want this done automatically)
    Getting the data off the websites is a project in itself, unless the sites in question offers some sort of very
    simple  (and static) GUI, or even an API. In any case, I would use a PC for the job.
    Lynx is a text based web client, it may be able to do some of the work for you.
    Erlo
  • Catwell
    0 Catwell over 16 years ago in reply to e14 Contributor
    The data I can take from the websites would mostly likely be in the form of RSS feeds. Weather and alerts are just news broadcast publicly, so getting the streams shouldn't be much of an issue.
    Cabe
    0 e14 Contributor over 16 years ago in reply to Catwell
    So all you have to do is to find a PLC with an appropriate interface that can be used to feed
    it you data stream.
    Maybe something like this: http://www.brodersen.dk/proinfo/data/field.htm
    Erlo
    You can do this easily from most SCADA/HMI packages that typically reside on a PLC network but if you want a pure "PLC solution" you could buy a Beckhoff CX9001. They are relatively inexpensive and run Windows CE, so you can write your own script to pull in anything you like off the web, save it to a file and then use the Beckhoff TwinCAT instructions to read the file data and do what you like with it. There are really many different ways to accomplish this.
