Embedded and Microcontrollers
Embedded Forum ARM board with LCD
  • Subscribers 484 subscribers
  • Views 503 views
  • arm;
  • development
  • kit;
ARM board with LCD
Former Member over 15 years ago
I am planning to work on ARM core processor, so I am searching for a kit, Which manufacturer will be good to startup and which core should I start with ? Kit should have graphical LCD interfaced.  Also suggest me with necessary software/ compilers. Thank you.
Chethan
  • firatkocak
    0 firatkocak over 15 years ago
    There are a lot of option you can fallow. I recommend you starting from ARM7 Mcu's. Olimex has starter kits and dev kits with reasonable prices. You may also prefer using Cortex-M3 Mcu's, too. I bough ST Primer2 kit from Farnell and its cost was quite acceptable. Together with the hardware you get programming and debugging opportunities with no extra cost and limitations.
    There are lots of things to say and it is up to your initial thoughts about what you intend to do witha starter kit.
    Firat
  • bheemarao
    0 bheemarao over 15 years ago
    Hi Chetan,
    Below is the link for selection for ARM based Board. it depends on the actual requirement and feature available with board.
    http://www.keil.com/boards/arm.asp
    Best Rdgs
    Bheema
  • bheemarao
    Hi Chetan,
    Here is another link for ARM based board which gives in detail:
    http://www.armkits.com/product/university.asp
    for software and tools on ARM pls click below:
    http://www.armkits.com/downcenter/software.asp
    Best Rgds
    Bheema
    0 Former Member over 15 years ago
    Hi, you can try this development platform with embedded GUI and support http://www.colibrigraphics.com
