Embedded and Microcontrollers
Embedded Forum 3A+ 3Phase Motor Controller
  • Answers 3 answers
  • Subscribers 503 subscribers
  • Views 942 views
  • 32bit
  • 8_bit
  • 32_bit
  • 16_bit
  • 3-phase
Catwell over 16 years ago
IC based brushless 3-phase motor controllers are on the rise, though I am not sure what is available past remote control airplane drive circuitry.
I want an IC that has the commutation functions built in, H-bridge built it, and anything above that would be welcomed icing on the cake.
One requirement, I need 3A+ on each phase.
What is available these days?
Cabe
  • WarrenW
    0 WarrenW over 16 years ago
    Try this little beastie....
    http://www.cirrus.com/en/pubs/proDatasheet/SA303U_C.pdf
  • WarrenW
    Or even better a farnell stocked item
    http://nz.farnell.com/cirrus-logic/sa306-ihz/switching-amp-60v-5a-3ph-64lqfp/dp/1673824?Ntt=1673824
    0 e14 Contributor over 16 years ago
    If you can afford the board space and want 5-10A, the Maxon DEC 50/5 OEM module is one option for sensored motors. Though not an IC, it is an integrated module that is relatively compact.
    http://www.maxonmotorusa.com/media_releases_10439.html
    It has some very nice features, runs up to 50V, and requires almost no external components.
  • Catwell
    0 Catwell over 16 years ago in reply to WarrenW
    Warren,
    Great option. That Cirrus chip looks intense, 10A per phase!
    Cabe
  • Catwell
    0 Catwell over 16 years ago in reply to e14 Contributor
    Shane,
    The board looks good too. I like the options it has. However, space is very limited for the project.
    Cabe
    0 e14 Contributor over 16 years ago in reply to Catwell
    Here is another very interesting new integrated 3-phase motor driver chip:
    http://focus.ti.com/lit/ds/symlink/drv8332.pdf
