Embedded and Microcontrollers
Embedded Forum 64Kbit DRAM equivalent
  • Replies 19 replies
  • Answers 2 answers
  • Subscribers 503 subscribers
  • Views 3630 views
  • repair
  • mn4264
  • dram
KennyMillar
KennyMillar over 15 years ago
Hi everyone
I'm looking for some ram chips I can use to repair a Roland sound module.
The fault lies in the MN4264 DRAM Chips and I need to replace them.
Does anyone know where I can buy MN4264-12 or equivalent chips these days?
It is a 64Kbit DRAM organised as 16K x 4bits.
  • ar_sys
    0 ar_sys over 15 years ago
    Hi Kenny,
    How many chip you need ? I think have a couple in some my old hardware.
    If it can be useful for you, I can de-solderd it an send you for free.
    Alessandro
  • KennyMillar
    0 KennyMillar over 15 years ago in reply to ar_sys
    Alessandro,
    The device has 4 chips in it - I'm not sure how many are faulty.
    One interesting thing is that if I put my oscilloscope probe onto the CAS line of the chip bank, the fault goes away - so looks like the timing in one of the chips has slipped out of spec.
  • ar_sys
    0 ar_sys over 15 years ago in reply to KennyMillar
    Kenny
    I hope the fault is in the DRAM chip and not in the driving circuit.
    I can send various brand and various access time chip so you can try.
    However 4264 must be a 64K x 1bit chip (see Micron part number list)
    I have also some 16K x 4bit but is is usually marked as 4416 41416 an so on.
    In this week end I see all I can find for you.
    Alessandro
  • KennyMillar
    I've seen confusion over this part number before - these are definitely 4 bit wide chips - I have the schematic for the system (Carl - I PMed you about that!)
    And I have a datasheet from Panasonic which shows the MN4264 as 4 bit. The micron data sheet does show it as 1 bit though. I believe both micron and panasonic have used the MN prefix at times.
  • KennyMillar
    0 KennyMillar over 15 years ago in reply to KennyMillar
    I may remove all 4 chips from the board and build a test rig for them.
    -K
  • ar_sys
    Kenny
    Plese tell me if your chip is 16 or 18 Pin. Please check also in your schematic how many address there are.
    -All  64K*1 I have (marked 4164 4264 4864) are in 16 pin package
    -All 16K*4 ( marked 4416  41416 etc ) are in 18 pin package
  • KennyMillar
    It's an 18-Pin device, and it is without doubt 16K x 4
    I have the correct data sheet for the part and I have the schematic for the board, both refer to MN4264-12 and both show a 4Bitx 16K device.
  • ar_sys
    Kenny,
    I am sorry but my 4264 are in 16 pin package. You can try whit 4416 chip?
    Compare before your datasheet whit TMS4416 or similar Dram.
  • KennyMillar
    Thanks anyway :-)
    I'll keep looking....
