Embedded and Microcontrollers
Embedded Forum Transistors not labeled, what to do?
  • Subscribers 502 subscribers
  • Views 641 views
  • test
  • transistor
  • embedded
ZeroSizeObject
ZeroSizeObject over 15 years ago
There are no identifying marks on a bunch of transistors I have in surplus. (Is it typical to have lots of extra parts laying around, or am I mad?)
How can I distinguish which transistor is a pnp or npn?
Zero
  • mookiebud
    0 mookiebud over 15 years ago
    Not mad - funny, I still have some 68HC711 windowed parts from the early-mid '90s. Oops, dating myself there.
    If you assume the transistors are bipolar, then you can use a multimeter with 'diode' function to determine PNP or NPN. Some multi-meters actually have transistor functions on them. Of course, once you determine PNP or NPN, they won't really be all that good except for experimenting as low voltage switches. Just too many other characteristics that you'd need to know to use them effectively.
    Anyhow, hope that helps.
    0 DAB over 15 years ago
    In the old days we used to have test equipment that you could stick a transistor in and it would show you the characteristics of the device.
    I doubt any still exist, so I would suggest you set up a simple amplifier circuit, one for NPN and one for PNP and plug them in a low voltage test rig to see which one works.
    From there you can adjust the amplifier gain and current drive capabilities.
    If you have an application for them, use the test rig to see if they would work, then go from their.
    It is probably not worth investing a whole lot of time as you can buy these things for pennies.
    Good luck,
    0 e14 Contributor over 15 years ago in reply to DAB
    There should still be multi-meters available that have the ability to do checks and get Beta for them.  I know my Craftsman meter does and it's about 13+ years old.  But DAB is right, I remember using a transistor "checkers" a few years ago.  Jerri Ellesworth shows one in one of her videos when she creates a cat's wisker based transistor.
    I have one of these
      http://au.element14.com/peak/dca55r/analyser-atlas-red/dp/3727440
      http://au.element14.com/peak/dca55t/analyser-atlas-cool-blue/dp/3727476  (same thing in different colour I think)
    I love it, stick the leads on almost anything, gives you the part type, gain and more. I pull it out any time I want to test or identify a part, match transistors, check their gain or threshold.
    Cheers,
    Marc
    Throw them away. They aren't worth the time and agro...
    Farnell sell NPNs for less than a penny and PNPs for about 6.4p...
    It's not like the days when I used to buy BC108's for a couple of shillings, and 7474 logic for a couple of pounds...  (Yes each.)
    Even if you get a thrill over achieving results for free, I find that a completed project is more satisfying.
    Chris
