Embedded and Microcontrollers
Embedded Forum Confused with headerfiles and undefined names
  • Subscribers 502 subscribers
  • Views 378 views
  • p18f458
  • header
  • Cube
  • led
  • define
  • mcu
  • bitnames
I'm working on my LED cube but have come across a problem.
I'm programming in C with MPLAB, C18 compiler and the P18F458 MCU.
I have included the headerfile of the MCU with: #include <p18f458.h>
After writing a piece of code, I get some errors about undefined symbols.
names like PORTA, TRISA work normal but bitnames don't work.
when I try to use bitnames to control timers, ports etc the compiler gives an error.
C:\Programmeren\Project_LEDcube\Software\Cube_Main_16082011\src\Main.c:61:Error [1105] symbol 'RE0' has not been defined
I do not understand why symbols like PORTE work and RE0 not, they are from the same headerfile if I'm right?
hope someone can help,
Futience
    0 e14 Contributor over 15 years ago
    After some try and error I have found a solution. I searched in the C18 userguide and found out that in stead of working with the symbol "RE0" I have to use "PORTEbits.RE0"
    I wasn't used to do it this way but it seems to work. Is there a simple way to convert this headerfile so I can use only "RE0" ???
    Futience
